Ir para o conteúdo principal
Martian Victory LED Screen Replacement
O que você precisa
  1. Martian Victory LED Screen Replacement, Back Plate: passo 1, imagem 1 %32 Martian Victory LED Screen Replacement, Back Plate: passo 1, imagem 2 %32
    • Unscrew the four 3.4 mm flat head screws
  2. Martian Victory LED Screen Replacement: passo 2, imagem 1 %32
    • Carefully lift the back plate off the watch. You will notice a lithium battery and rubber gasket attached to the back plate.
  3. Martian Victory LED Screen Replacement, Lithium Battery: passo 3, imagem 1 %32
    • If not replacing lithium battery, skip down two steps.
    • Using the plastic removal tool, pry the battery from the backing plate. The battery is simply attached with glue.
  4. Martian Victory LED Screen Replacement: passo 4, imagem 1 %32
    • Desolder the battery connections from the motherboard. Learn how to solder components here!
  5. Martian Victory LED Screen Replacement, LED Screen: passo 5, imagem 1 %32
    • Locate the ribbon connection, and use remove the clips holding the strip on each side using needle tool.
  6. Martian Victory LED Screen Replacement: passo 6, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • With a pair of tweezers, carefully remove the ribbon strip connection.
  7. Martian Victory LED Screen Replacement: passo 7, imagem 1 %32
    • Remove the screw driver holding the LED screen and Speaker in place.
  8. Martian Victory LED Screen Replacement: passo 8, imagem 1 %32
    • Insert a small flat screw driver under the speaker in order to remove it.
  9. Martian Victory LED Screen Replacement: passo 9, imagem 1 %32 Martian Victory LED Screen Replacement: passo 9, imagem 2 %32
    • Using tweezers, remove the speaker and move off to the side.
  10. Martian Victory LED Screen Replacement: passo 10, imagem 1 %32 Martian Victory LED Screen Replacement: passo 10, imagem 2 %32
    • Place a small flat head screwdriver under the LED screen, and carefully push it out of it's socket.
  11. Martian Victory LED Screen Replacement: passo 11, imagem 1 %32
    • Remove final connection to accelerometer. The LED screen is now separated from the device.
Conclusão
Robert Sanchez
Membro desde: 10/31/16
201 Reputação
Autoria de 2 guias
Equipe
IUPUI, Team 3-3, Baechle Fall 2016 Membro de IUPUI, Team 3-3, Baechle Fall 2016
IUPUI-BAECHLE-F16S3G3
Membros da 4
Autoria de 8 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 219
