Ir para o conteúdo principal
Marshall Stanmore II Power Jack Replacement
O que você precisa
  1. Marshall Stanmore II Power Jack Replacement, Rear Panel: passo 1, imagem 1 %32 Marshall Stanmore II Power Jack Replacement, Rear Panel: passo 1, imagem 2 %32
    • Turn off the device and unplug the cable from the wall and the speaker.
    • Lay the speaker with the back panel facing up on a flat, stable work surface.
  2. Marshall Stanmore II Power Jack Replacement: passo 2, imagem 1 %32 Marshall Stanmore II Power Jack Replacement: passo 2, imagem 2 %32
    • Use a Phillips #2 screwdriver to remove the ten 20.5 mm screws that secure the rear panel to the chassis.
  3. Marshall Stanmore II Power Jack Replacement: passo 3, imagem 1 %32 Marshall Stanmore II Power Jack Replacement: passo 3, imagem 2 %32
    • Carefully lift the rear panel and let it rest on an object, like a stack of books, to avoid straining the cables.
    • Do not attempt to fully remove the panel, as this will damage the connections inside.
  4. Marshall Stanmore II Power Jack Replacement, Power Jack: passo 4, imagem 1 %32 Marshall Stanmore II Power Jack Replacement, Power Jack: passo 4, imagem 2 %32
    • Set the panel back in place.
    • Use a #1 Phillips screwdriver to remove the two 11.7 mm screws that secure the power jack.
    • When removed for the first time, the jack will remain in place until it is pulled out.
  5. Marshall Stanmore II Power Jack Replacement: passo 5, imagem 1 %32 Marshall Stanmore II Power Jack Replacement: passo 5, imagem 2 %32
    • Find the power jack cable inside of the removable panel. It is located in the upper, right corner of the panel interior.
  6. Marshall Stanmore II Power Jack Replacement: passo 6, imagem 1 %32 Marshall Stanmore II Power Jack Replacement: passo 6, imagem 2 %32 Marshall Stanmore II Power Jack Replacement: passo 6, imagem 3 %32
    • Depress the white plastic clip while pulling the connector up.
    • Remove the power jack.
Conclusão
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 18
Últimos 30 dias: 60
Ao todo: 859
