Ir para o conteúdo principal
Maquet Servo-U O2 Supply Replacement
  1. Maquet Servo-U O2 Supply Replacement, O2 Supply: passo 1, imagem 1 %32
    • Turn the inspiratory channel lock one quarter of a turn to release.
    • Lift off the inspiratory channel cover.
    • WARNING! The inspiratory channel cover shall be kept in place once maintenance has been performed. Otherwise the gas modules can be affected and deliver the wrong flow.
    Pergunte ao FixBot
  2. Maquet Servo-U O2 Supply Replacement: passo 2, imagem 1 %32
    • Lower the locking catch.
    Pergunte ao FixBot
  3. Maquet Servo-U O2 Supply Replacement: passo 3, imagem 1 %32 Maquet Servo-U O2 Supply Replacement: passo 3, imagem 2 %32
    • Disconnect the O2 cell connector.
    • Lift and discard the O2 cell with the rubber seal to special waste and/or remove and discard the bacterial filter to hazardous waste.
    Pergunte ao FixBot
  4. Maquet Servo-U O2 Supply Replacement: passo 4, imagem 1 %32
    • Ensure that the new rubber seal is intact, then firmly put in a new bacterial filter.
    Pergunte ao FixBot
  5. Maquet Servo-U O2 Supply Replacement: passo 5, imagem 1 %32
    • Connect the O2 cell connector.
    • Put the O2 cell in position.
    • Close the locking catch.
    Pergunte ao FixBot
  6. Maquet Servo-U O2 Supply Replacement: passo 6, imagem 1 %32
    • Put the inspiratory channel cover in position.
    • Tighten the inspiratory channel lock.
    • Perform a pre-use check stated in Troubleshooting Page.
    Pergunte ao FixBot
Linha de Chegada
Equipe
Cal Poly, Team S7-G2, Paton Spring 2020 Membro de Cal Poly, Team S7-G2, Paton Spring 2020
CPSU-PATON-S20S7G2
3 Membros
Autoria de 5 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 76
Ao todo: 2,850
