Ir para o conteúdo principal
MapKeyboard Tutorial
      • 1. When one of your keyboard's keys is broken, you don't want to spend a lot of money to replace the entire keyboard because of one key
      • 2. You can use a software called "MapKeyboard"
      • 3. Start the software and select the key you will use to replace the broken key
      • 4. Select "ReMap selected key to" and select the broken key "G"
      • 5. Click on "Save layout" and the laptop will restart
      • 6. After restarting, you will find that the key you set can be typed with “G” so that you can continue to use your keyboard without changing it
      • 7. If you want to restore the layout of the keyboard, you can start the software again, click on "Reset keyboard layout"
      • 8.After the restart, it will be restored
      Pergunte ao FixBot
      Comentar
Conclusão
Laptop
Membro desde: 05/29/18
1.029 Reputação
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 10
Últimos 30 dias: 41
Ao todo: 1,447
