Introdução
This guide will show you the necessary steps to replace the forward/reverse switch. It shows how to remove the battery and the outer casing, in order to locate the forward/reverse switch on the drill.
O que você precisa
Hold the drill upright.
Place your finger on the white battery-release button.
Hold the drill upright with the back panel facing you.
Unscrew the two 18 mm screws from the back panel using a Phillips PH2 screwdriver.
4 outras pessoas executaram este guia.
