Ir para o conteúdo principal
Maingear Vector Laptop Screen Replacement
O que você precisa
    • pull off the black bezel around the deges
    • it is held on by double-sided tape. be careful not to break the bezel it is a somewhat thin plastic sheet.
    Pergunte ao FixBot
    Comentar
  1. Ferramenta utilizada neste passo:
    • carefully pry up the bottom of the screen. there is double-sided tape holding it to the back.
    • pry on one side at a time slowly and once you can fit a pair of tweezers befind the screen grab the tape. when yo pull the tape it will come off like 3m command hooks
    • be careful not to rip the tape
    • the tape is in two vertical strips about an inch from the edge
    Pergunte ao FixBot
    Comentar
    • the replacement screen is a lp156wfg(sp)(B2) on the maingear vector mg vctr001 1660ti from 2020
    Pergunte ao FixBot
    Comentar
Conclusão
To reassemble your device, follow these instructions in reverse order. this is not a complete guide there is only enough info for you to know how to open it little steps are missing.
djluke mon
Membro desde: 04/18/22
97 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 35
Ao todo: 1,099
