Introdução
Use this guide to remove the black covers protecting the mouse's white click button pieces.
O que você precisa
Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
18 outras pessoas executaram este guia.
6Comentários do guia
how are you supposed to put the feet back?
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Are the side buttons the same?
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
