Ir para o conteúdo principal
Main Click Buttons
O que você precisa
  1. Main Click Buttons, Click Buttons: passo 1, imagem 1 %32 Main Click Buttons, Click Buttons: passo 1, imagem 2 %32
    • Use a blue spudger to pry all 4 mouse feet off the bottom of the mouse.
    Pergunte ao FixBot
    Comentar
  2. Main Click Buttons: passo 2, imagem 1 %32 Main Click Buttons: passo 2, imagem 2 %32
    • Use a #00 screwdriver (3x5mm) to unscrew all 6 screws from under the mouse feet.
    Pergunte ao FixBot
    Comentar
  3. Main Click Buttons: passo 3, imagem 1 %32 Main Click Buttons: passo 3, imagem 2 %32
    • Use a blue spudger to open the bottom battery port.
    Pergunte ao FixBot
    Comentar
  4. Main Click Buttons: passo 4, imagem 1 %32 Main Click Buttons: passo 4, imagem 2 %32
    • Lift the top of the mouse from the base of the mouse (separate mouse in half) to expose the internal hardware.
    Pergunte ao FixBot
    Comentar
  5. Main Click Buttons: passo 5, imagem 1 %32 Main Click Buttons: passo 5, imagem 2 %32 Main Click Buttons: passo 5, imagem 3 %32
    • Use pliers to grip and remove the black covers over the button — the black cover and the button, a small white plastic piece, should come off).
    Pergunte ao FixBot
    Comentar
Conclusão
18 outras pessoas executaram este guia.
6Comentários do guia
how are you supposed to put the feet back?
Owen Yuen - Responder Compartilhar
you have to buy new ones… i’m more concerned of using pliers to take the switch apart, when ideally you should desolder it and replace it with a proper omron switch (not made in china)
Erick Alonso Duque - Responder Compartilhar
He is only removing the cover, not the whole button. But doing it with pliers is skipping that it has two clips, one at each end and you could damage the board just twisting and pulling
Russell Reeling - Responder Compartilhar
Are the side buttons the same?
S I - Responder Compartilhar
What do you do after step 5? And that copper spring looks wrong. It shouldn’t look like that. The correct positioning is this: https://community.pcgamingwiki.com/galle...
Nonalbert Noneinstein - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 32
Últimos 30 dias: 194
Ao todo: 25,543
