Ir para o conteúdo principal
Magic Bullet NutriBullet Rubber Gasket Replacement
O que você precisa
    1. Magic Bullet NutriBullet Rubber Gasket Replacement, Rubber Gasket: passo 1, imagem 1 %32
      • Separate the blending blade lid from the cup.
      Pergunte ao FixBot
      Comentar
    2. Magic Bullet NutriBullet Rubber Gasket Replacement: passo 2, imagem 1 %32 Magic Bullet NutriBullet Rubber Gasket Replacement: passo 2, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Using tweezers, grab the gasket at the indented lip which is located on the side of the blending blade.
      • Slowly pry the rubber gasket up.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Geary Yu
Membro desde: 01/22/15
1.277 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-8, Maness Winter 2015 Membro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membros
Autoria de 19 guias
11Comentários do guia
The trouble is, this process doesn't work in reverse order as the gasket keeps popping up where you are not applying the pressure. You could do this all day and I'm sure it would be great therapy for OCD.
lizzywade888 - Responder Compartilhar
I want to replace the rubber gasket. My trouble is I can't find a gasket that states it will fit this model. magic Bullet NUTRIBULLET model number NB-WL007-02 Can you tell me where to purchase this? Thanks!
Marcia Sikes
today_first@cox.net
todayfirst - Responder Compartilhar
My understanding is that if it's leaking all the way into the base and not out the sides, it's likely not the main gasket (a faulty one of these would probably cause it to leak out the sides). This is a really good video that explains how to remove the blade and replace the washers that act as gaskets to stop liquid from dripping straight through the center/blade area.
https://www.youtube.com/watch?v=n0fiNRwh...
Tracy Hamilton - Responder Compartilhar
Thanks a lot.
Kayla Martin - Responder Compartilhar
lizzywad is correct. The %#*@ thing wont stay in, it keeps popping out.  What else can be done?
deborah blair - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 31
Últimos 30 dias: 166
Ao todo: 38,427
