Introdução
The exterior component of the NutriBullet’s powerbase consist of a silver, plastic shell casing. Use this guide to replace the cylindrical shell to ensure no leakage, exposure of wires or spinning components are showing through.
O que você precisa
Wiggle the outside casing upward until it separates from the powerbase.
5 outras pessoas executaram este guia.
4Comentários do guia
Ok so what happens after Step 8 of pulling the Nutribullet apart? Did I miss something?? Now I have my Nutribullet in pieces on the benchtop. Now what??
Same problem. I can't get the drive gear on the top loose which I assume will actual give me access to the wiring. I am guessing it is a pressure fit but I can't get anything under it to pry it loose. If it is a screw attachment don't want to break it. Help.
So what happens next? What is one suppose to do? Stupid help, I would say
I tried step number 8 and the outside casing still won't slide off. What do I do now?
