Ir para o conteúdo principal
Magic Bullet NutriBullet Base Replacement
O que você precisa
    1. Magic Bullet NutriBullet Base Replacement, Base: passo 1, imagem 1 %32
      • Unplug the device from the wall and turn the powerbase upside down.
      Pergunte ao FixBot
      Comentar
    2. Magic Bullet NutriBullet Base Replacement: passo 2, imagem 1 %32 Magic Bullet NutriBullet Base Replacement: passo 2, imagem 2 %32
      • Unscrew the four 10mm screws located on the bottom of the powerbase using the Phillips Head #2 Screwdriver.
      Pergunte ao FixBot
      Comentar
    3. Magic Bullet NutriBullet Base Replacement: passo 3, imagem 1 %32
      • Once the screws are removed, use slight tension to pull the plastic base up.
      • Make sure the cord does not get caught or frayed by the fan, which is located in the center of the power base.
      Pergunte ao FixBot
      Comentar
Conclusão
3 outras pessoas executaram este guia.
Angela Wong
Membro desde: 01/22/15
1.177 Reputação
Autoria de 3 guias
Equipe
Cal Poly, Team 19-8, Maness Winter 2015 Membro de Cal Poly, Team 19-8, Maness Winter 2015
CPSU-MANESS-W15S19G8
4 Membros
Autoria de 19 guias
3Comentários do guia
So far it was easy! Yeah!
Elaine - Responder Compartilhar
With a lot of force can’t get bottom of even 4 screws removed Bullet don’t work anymore may be a piece of junk now
Tommy Simpson - Responder Compartilhar
Where can you buy the base to replace?
Anne-Christine von Wetter - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 15
Últimos 30 dias: 69
Ao todo: 10,903
