Ir para o conteúdo principal
Magic Bullet MB1001B Power Cord Replacement
O que você precisa
  1. Magic Bullet MB1001B Power Cord Replacement, Power Cord: passo 1, imagem 1 %32
    • Remove the four rubber pegs from the feet on the base of the Magic Bullet using the spudger.
    Pergunte ao FixBot
    Comentar
  2. Magic Bullet MB1001B Power Cord Replacement: passo 2, imagem 1 %32
    • Remove the four 14.0 mm Phillips head screws in the feet of the base of the Magic Bullet using the Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  3. Magic Bullet MB1001B Power Cord Replacement: passo 3, imagem 1 %32
    • Remove the black base plate.
    Pergunte ao FixBot
    Comentar
  4. Magic Bullet MB1001B Power Cord Replacement: passo 4, imagem 1 %32
    • Remove the two 13.0 mm Phillips head screws from the white plastic cable guide using a Phillips #1 screwdriver.
    Pergunte ao FixBot
    Comentar
  5. Magic Bullet MB1001B Power Cord Replacement: passo 5, imagem 1 %32
    • Remove the white plastic cable guide.
    Pergunte ao FixBot
    Comentar
  6. Magic Bullet MB1001B Power Cord Replacement: passo 6, imagem 1 %32
    • Remove the two crimp caps from the end of the wires.
    • You will need to purchase new crimp caps and use pliers to crimp the new crimp caps on the connected wires during reassembly.
    Pergunte ao FixBot
    Comentar
  7. Magic Bullet MB1001B Power Cord Replacement: passo 7, imagem 1 %32
    • Separate the black wires of the power cord from the red wires on the Magic Bullet base.
    • Be sure to mark which wires are connected before separating them to ensure that they are properly reconnected during reassembly.
    Pergunte ao FixBot
    Comentar
Conclusão
Bridget Carr
Membro desde: 10/06/15
266 Reputação
Autoria de 1 guia
Equipe
Cal Poly, Team 12-13, Maness Fall 2015 Membro de Cal Poly, Team 12-13, Maness Fall 2015
CPSU-MANESS-F15S12G13
4 Membros
Autoria de 8 guias
2Comentários do guia
I accidentally burnt through my power cord. What type of power cord do I need to replace it?
virginia.cooke - Responder Compartilhar
Where do we get a new power cord, and if that does not work, what do we do next?
davidcohnkettlebells - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 8
Últimos 30 dias: 29
Ao todo: 2,939
