Ir para o conteúdo principal
Magellan RoadMate 5250T-LM Motherboard Replacement
O que você precisa
  1. Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: passo 1, imagem 1 %32 Magellan RoadMate 5250T-LM Motherboard Replacement, Motherboard: passo 1, imagem 2 %32
    • Remove all four 5mm screws from the back of the device using a Phillips Head screwdriver size 000.
  2. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 2, imagem 1 %32 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 2, imagem 2 %32
    • Open the casing of the device using a plastic spudger.
  3. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 3, imagem 1 %32 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the tape covering the display connector on top of the motherboard.
    • Use a nylon spudger to flip up the black tab on the ZIF connector.
    • Pull the ribbon cable out with tweezers.
    • The ribbon cable may fall out once the tape is removed.
  4. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 4, imagem 1 %32 Magellan RoadMate 5250T-LM Motherboard Replacement: passo 4, imagem 2 %32
    • Remove the motherboard from the device by unscrewing all three 4mm screws that are connecting it to the casing with a Phillips Head screwdriver size 000.
  5. Magellan RoadMate 5250T-LM Motherboard Replacement: passo 5, imagem 1 %32
    • Disconnect the original battery from the motherboard and the speaker by desoldering all five wires that attach them to the motherboard.
    • Click here to visit iFixIt's guide on soldering.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 6
Duração total: 306
