Ir para o conteúdo principal
Magellan RoadMate 5236T-LM Speaker Replacement
O que você precisa
  1. Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: passo 1, imagem 1 %32 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: passo 1, imagem 2 %32 Magellan RoadMate 5236T-LM Speaker Replacement, Back Cover: passo 1, imagem 3 %32
    • Place the device face down on a flat surface.
    • Remove the four 5mm screws at each corner using a #000 Phillips head screwdriver.
  2. Magellan RoadMate 5236T-LM Speaker Replacement: passo 2, imagem 1 %32 Magellan RoadMate 5236T-LM Speaker Replacement: passo 2, imagem 2 %32 Magellan RoadMate 5236T-LM Speaker Replacement: passo 2, imagem 3 %32
    • Gently wedge a plastic opening tool into the seam along the side of the device.
    • Slide the tool along the seam to pry apart the front and back covers.
  3. Magellan RoadMate 5236T-LM Speaker Replacement: passo 3, imagem 1 %32 Magellan RoadMate 5236T-LM Speaker Replacement: passo 3, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • A ribbon cable attaches the display screen and the motherboard via a ZIF connector. Remove the tape covering where the ZIF connector connects to the mother board.
    • Use tweezers to disconnect the ZIF connector from the motherboard.
    • The ZIF connector may disconnect itself from the motherboard when removing the tape.
  4. Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: passo 4, imagem 1 %32 Magellan RoadMate 5236T-LM Speaker Replacement, Speaker: passo 4, imagem 2 %32
    • Lay the back panel on a flat surface with the battery, motherboard, and speaker facing up.
    • Use a plastic opening tool to gently pull the battery away from the back panel in order to remove the adhesive that helps the battery stick to the panel.
  5. Magellan RoadMate 5236T-LM Speaker Replacement: passo 5, imagem 1 %32
    • Unscrew the two 5mm screws using a Phillips #000 screwdriver.
  6. Magellan RoadMate 5236T-LM Speaker Replacement: passo 6, imagem 1 %32 Magellan RoadMate 5236T-LM Speaker Replacement: passo 6, imagem 2 %32 Magellan RoadMate 5236T-LM Speaker Replacement: passo 6, imagem 3 %32
    • Use a Phillips #000 screwdriver to remove three 5mm screws that hold the motherboard down to the the back panel.
    • Remove the battery, speaker and motherboard. Place them on a flat surface upside down.
  7. Magellan RoadMate 5236T-LM Speaker Replacement: passo 7, imagem 1 %32
Conclusão
Felix Muwanguzi
Membro desde: 10/24/16
199 Reputação
Autoria de 2 guias
Equipe
UMass Dartmouth, Team 4-7, Catania Fall 2016 Membro de UMass Dartmouth, Team 4-7, Catania Fall 2016
UMASSD-CATANIA-F16S4G7
Membros da 3
Autoria de 5 guias
Um comentário
Where can I find a replacement speaker?
Tom Phillips - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 2
Últimos 30 dias: 8
Duração total: 165
