Ir para o conteúdo principal
Magellan RoadMate 2120T-LM Battery Replacement
O que você precisa
  1. Magellan RoadMate 2120T-LM Battery Replacement, Battery: passo 1, imagem 1 %32 Magellan RoadMate 2120T-LM Battery Replacement, Battery: passo 1, imagem 2 %32 Magellan RoadMate 2120T-LM Battery Replacement, Battery: passo 1, imagem 3 %32
    • Turn the GPS over on its backside and remove the six 3 mm Phillips #1 screws.
  2. Magellan RoadMate 2120T-LM Battery Replacement: passo 2, imagem 1 %32 Magellan RoadMate 2120T-LM Battery Replacement: passo 2, imagem 2 %32
    • Pry up on back panel with black spudger
  3. Magellan RoadMate 2120T-LM Battery Replacement: passo 3, imagem 1 %32
    • Disconnect battery and speaker cables from the motherboard at indicated places.
  4. Magellan RoadMate 2120T-LM Battery Replacement: passo 4, imagem 1 %32
    • Use a spudger to remove the battery from the back panel.
    • If at all possible, please try to use a regular nylon spudger before resorting to a metal spudger. Metal spudgers are much sharper, and have the potential to accidentally pierce the battery.
    • There is a strong adhesive holding the battery to the back panel.
    • This step is not a prerequisite for replacement of other components.
Conclusão
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 1
Últimos 7 dias: 1
Últimos 30 dias: 8
Duração total: 326
