Ir para o conteúdo principal
Magellan RoadMate 1440 Antenna Replacement
O que você precisa
  1. Magellan RoadMate 1440 Antenna Replacement, Magellan RoadMate 1440 Back Cover Disassembly: passo 1, imagem 1 %32
    • Place the GPS with the screen facing down.
  2. Magellan RoadMate 1440 Antenna Replacement: passo 2, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 2, imagem 2 %32
    • Remove the four 4.2 mm screws on the back cover of the device using a Phillips #0 screwdriver.
  3. Magellan RoadMate 1440 Antenna Replacement: passo 3, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 3, imagem 2 %32
    • Remove the two 4.2mm screws at the bottom of the device using a Phillips #0 screwdriver.
  4. Magellan RoadMate 1440 Antenna Replacement: passo 4, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 4, imagem 2 %32 Magellan RoadMate 1440 Antenna Replacement: passo 4, imagem 3 %32
    • Insert the black spudger into the crease in the side of the GPS.
    • Move the end of the spudger down to break the seal between the two plastic shells.
    • Continue doing this along each side of the GPS to ensure a smooth removal.
  5. Magellan RoadMate 1440 Antenna Replacement: passo 5, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 5, imagem 2 %32 Magellan RoadMate 1440 Antenna Replacement: passo 5, imagem 3 %32
    • Fully separate the two sides of the case.
    • Remove the tape on the battery wires and the tape on the speaker wires.
  6. Magellan RoadMate 1440 Antenna Replacement, Battery: passo 6, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement, Battery: passo 6, imagem 2 %32
    • Use the black spudger to break the seal between the adhesive and battery. Use the same spudger to continue to pry the battery from the backing
    • This may be a little tough to separate the battery and the adhesive
  7. Magellan RoadMate 1440 Antenna Replacement: passo 7, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 7, imagem 2 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Lift the battery from the device
    • Once the battery is free from the adhesive, remove the piece of tape with a pair of tweezers that is covering the connection of the battery to the motherboard.
  8. Magellan RoadMate 1440 Antenna Replacement: passo 8, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement: passo 8, imagem 2 %32
    • Unplug the battery from the mother board by pulling back the clips and pulling the wires away from the motherboards receptacle
    • It is important for your and the device's safety to remove the battery before continuing with any other part removals.
    • It is not necessary to separate the red and white wires from the battery. A replacement battery pack will come with similar wires already attached.
  9. Magellan RoadMate 1440 Antenna Replacement, Antenna: passo 9, imagem 1 %32 Magellan RoadMate 1440 Antenna Replacement, Antenna: passo 9, imagem 2 %32 Magellan RoadMate 1440 Antenna Replacement, Antenna: passo 9, imagem 3 %32
    • Identify the antenna.
    • Locate the two screws in the antenna.
    • Use a Phillips #0 screwdriver to remove the two 2.5mm Phillips #0 screws.
  10. Magellan RoadMate 1440 Antenna Replacement: passo 10, imagem 1 %32
    • After the screws have been removed, move the motherboard so that it is sitting in the side with the speaker and battery.
    • Using a soldering iron, melt the solder connecting the antenna to the motherboard. For instructions on how to use the soldering iron, refer to Soldering Technique Guide for instructions.
    • The soldering iron will be hot. Handle it with caution.
Conclusão
Benton Burns
Membro desde: 03/21/16
209 Reputação
Autoria de 2 guias
Equipe
Clemson, Team 7-3, Benson Spring 2016 Membro de Clemson, Team 7-3, Benson Spring 2016
CLEM-BENSON-S16S7G3
Membros da 4
Autoria de 7 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 9
Duração total: 211
