Ir para o conteúdo principal
MageGee Key Caps Replacement
O que você precisa
    1. MageGee Key Caps Replacement, Key Caps: passo 1, imagem 1 %32
      • Test out which keys are the ones that are sticking and giving you trouble.
      • If you have a lot of keys that stick you might want to take note of which ones they or, or alternatively replace your entire keyboard's key caps.
      Pergunte ao FixBot
      Comentar
    2. MageGee Key Caps Replacement: passo 2, imagem 1 %32 MageGee Key Caps Replacement: passo 2, imagem 2 %32
      • Remove the damaged keys with a key cap remover by gently pressing onto the desired key cap. Pull gently and the key cap will come off.
      • Make a note of where the keys are located so you know where to replace them.
      Pergunte ao FixBot
      Comentar
    3. MageGee Key Caps Replacement: passo 3, imagem 1 %32
      • When removing the keys, remember where each one goes. You can place it in the order it was taken out to help you keep track.
      Pergunte ao FixBot
      Comentar
    4. MageGee Key Caps Replacement: passo 4, imagem 1 %32 MageGee Key Caps Replacement: passo 4, imagem 2 %32
      Ferramenta utilizada neste passo:
      • Check the keyboard for any blockages or obstructions and remove them with tweezers.
      • Alternatively: use your fingers or any other grabbing tools like a pair of small tongs.
      Pergunte ao FixBot
      Comentar
    5. MageGee Key Caps Replacement: passo 5, imagem 1 %32
      • Clean the area with a cloth or antibacterial wipe to remove any debris you might have missed.
      • Remember, water damages electronics so be very careful with this step.
      Pergunte ao FixBot
      Comentar
    6. MageGee Key Caps Replacement: passo 6, imagem 1 %32
      • Check your removed key caps to see if they are still functional, if not, you may want to get additional key caps to replace the old ones.
      Pergunte ao FixBot
      Comentar
    7. MageGee Key Caps Replacement: passo 7, imagem 1 %32
      • If your key caps were damaged, take out corresponding new key caps to replace the old damaged ones.
      Pergunte ao FixBot
      Comentar
    8. MageGee Key Caps Replacement: passo 8, imagem 1 %32 MageGee Key Caps Replacement: passo 8, imagem 2 %32 MageGee Key Caps Replacement: passo 8, imagem 3 %32
      • Insert the new key caps in by lining it up with the other keys and pressing it gently into the correct place.
      Pergunte ao FixBot
      Comentar
    9. MageGee Key Caps Replacement: passo 9, imagem 1 %32
      • Test out your new key caps and double check its functionality.
      Pergunte ao FixBot
      Comentar
    10. MageGee Key Caps Replacement: passo 10, imagem 1 %32 MageGee Key Caps Replacement: passo 10, imagem 2 %32
      • Plug in your keyboard and there you have it, a functional mechanical keyboard.
      • If your keyboard is not fixed, it may be a circuit issue which will result in needing your whole keyboard needing to be replaced.
      Pergunte ao FixBot
      Comentar
Conclusão
Now your keys on your mechanical keyboard should be working as good as new.
Lisa Nguyen
Membro desde: 06/29/21
181 Reputação
Autoria de 1 guia
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 18
Últimos 30 dias: 92
Ao todo: 6,070
