Introdução
Please remember that these controllers are not designed to be repaired so do not be surprised if you need to be rough with it or something was not initially installed correctly. Also, the same kind of screw was used throughout the controller.
O que você precisa
Use a soldering iron to de-solder both vibration motor wires from the motherboard.
Quase terminado!
Conclusão
