Ir para o conteúdo principal
Macintosh Powerbook 5300cs Keyboard Replacement
O que você precisa
  1. Macintosh Powerbook 5300cs Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • The battery compartment is located in the front-right side of the laptop.
    Pergunte ao FixBot
    Comentar
  2. Macintosh Powerbook 5300cs Keyboard Replacement: passo 2, imagem 1 %32
    • To insert the battery, gently slide it into the compartment until it clicks in place.
    • To remove, slide the button highlighted in the red rectangle to the right to release the battery and slide it from the compartment.
    Pergunte ao FixBot
    Comentar
  3. Macintosh Powerbook 5300cs Keyboard Replacement, Keyboard: passo 3, imagem 1 %32
    • With the laptop upside down and with the battery removed, use a Torx #9 screw driver to remove the three .84 in. screws shown.
    Pergunte ao FixBot
    Comentar
  4. Macintosh Powerbook 5300cs Keyboard Replacement: passo 4, imagem 1 %32 Macintosh Powerbook 5300cs Keyboard Replacement: passo 4, imagem 2 %32
    • Carefully pull up on the front of the keyboard to pop it out from the case.
    • Then slide the back out so the keyboard becomes nearly free.
    Pergunte ao FixBot
    Comentar
  5. Macintosh Powerbook 5300cs Keyboard Replacement: passo 5, imagem 1 %32 Macintosh Powerbook 5300cs Keyboard Replacement: passo 5, imagem 2 %32 Macintosh Powerbook 5300cs Keyboard Replacement: passo 5, imagem 3 %32
    • Disconnect the ribbon that is connecting the keyboard to the rest of the computer.
    • Pull the keyboard out and repair or replace as needed.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Ronan
Membro desde: 10/10/11
72 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-1, Regan Fall 2011 Membro de Cal Poly, Team 6-1, Regan Fall 2011
CPSU-REGAN-F11S6G1
4 Membros
Autoria de 6 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 11
Últimos 30 dias: 43
Ao todo: 1,177
