Ir para o conteúdo principal
Macintosh PowerBook 165c Keyboard Replacement
O que você precisa
  1. Macintosh PowerBook 165c Keyboard Replacement, Battery: passo 1, imagem 1 %32
    • Orient the computer so the battery is facing you.
    • Slide the gray plastic battery cover to the right.
    Pergunte ao FixBot
    Comentar
  2. Macintosh PowerBook 165c Keyboard Replacement: passo 2, imagem 1 %32
    • Pull the battery toward yourself until it is fully detached.
    Pergunte ao FixBot
    Comentar
  3. Macintosh PowerBook 165c Keyboard Replacement, Input/Output Door: passo 3, imagem 1 %32
    • Orient the computer right side up with the rear facing you.
    • Open the Input/Output (I/O) door.
    Pergunte ao FixBot
    Comentar
  4. Macintosh PowerBook 165c Keyboard Replacement: passo 4, imagem 1 %32
    • Carefully bend the door into an arch until one of the pins releases from its slot.
    • Once one of the pins is free, remove the I/O door from the computer.
    Pergunte ao FixBot
    Comentar
  5. Macintosh PowerBook 165c Keyboard Replacement, Lower Case: passo 5, imagem 1 %32
    • Orient the computer with the bottom facing up and rear facing you. You should be able to read the Macintosh label in this position.
    Pergunte ao FixBot
    Comentar
  6. Macintosh PowerBook 165c Keyboard Replacement: passo 6, imagem 1 %32
    • Use a T8 torx screwdriver to remove the 6.8mm long screw above and to the right of the modem jack.
    • Twist counter clockwise to remove the screw.
    Pergunte ao FixBot
    Comentar
  7. Macintosh PowerBook 165c Keyboard Replacement: passo 7, imagem 1 %32
    • Use a T10 torx screwdriver to remove the four, 18mm long screws from the lower case.
    Pergunte ao FixBot
    Comentar
  8. Macintosh PowerBook 165c Keyboard Replacement: passo 8, imagem 1 %32 Macintosh PowerBook 165c Keyboard Replacement: passo 8, imagem 2 %32
    • Place your hands on the lower case, just above the I/O panel, and slowly lift the lower case a few inches above the main body of the computer.
    • Release the large, gray interconnect ribbon cable just behind the I/O panel.
    • Caution: Lower case cannot be fully removed until two plastic clips in the front corners are released. See the following step for details.
    Pergunte ao FixBot
    Comentar
  9. Macintosh PowerBook 165c Keyboard Replacement: passo 9, imagem 1 %32 Macintosh PowerBook 165c Keyboard Replacement: passo 9, imagem 2 %32
    • Place your thumb on the upper case, inside the empty battery slot, and your index finger near your thumb on the left side of the lower case.
    • Pinch your thumb and index finger towards each other to release the clip. Without releasing pressure on the pinch grip, use your index finger to push the lower case upwards.
    • Lift the lower case to remove it.
    Pergunte ao FixBot
    Comentar
  10. Macintosh PowerBook 165c Keyboard Replacement, Trackball: passo 10, imagem 1 %32 Macintosh PowerBook 165c Keyboard Replacement, Trackball: passo 10, imagem 2 %32
    • Locate the trackball assembly. It is in the upper case and can be identified by a green circuit board.
    • Open the white tab fastener by pulling out on each side. and remove the green and silver ribbon cable.
    • Remove the green and silver ribbon cable by gently pulling it away from the opened tab fastener.
    Pergunte ao FixBot
    Comentar
  11. Macintosh PowerBook 165c Keyboard Replacement: passo 11, imagem 1 %32
    • Use a T8 torx screwdriver to remove the six, 6.8mm long screws from the top of the green circuit board.
    Pergunte ao FixBot
    Comentar
  12. Macintosh PowerBook 165c Keyboard Replacement: passo 12, imagem 1 %32
    • Remove all four components of the trackball assembly by lifting upward.
    • The four components of the trackball assembly should include: the green circuit board, a metal support, the track ball, and the casing.
    Pergunte ao FixBot
    Comentar
  13. Macintosh PowerBook 165c Keyboard Replacement, Keyboard: passo 13, imagem 1 %32 Macintosh PowerBook 165c Keyboard Replacement, Keyboard: passo 13, imagem 2 %32
    • Open the left most white tab fastener in the lower left corner by pulling up on each side.
    • Remove the ribbon cable by gently pulling it away from the opened tab fastener.
    Pergunte ao FixBot
    Comentar
  14. Macintosh PowerBook 165c Keyboard Replacement: passo 14, imagem 1 %32 Macintosh PowerBook 165c Keyboard Replacement: passo 14, imagem 2 %32
    • Open the right of the two small, white tab fasteners by pulling up on both sides.
    • Remove the green and silver ribbon cable from the tab fastener.
    Pergunte ao FixBot
    Comentar
  15. Macintosh PowerBook 165c Keyboard Replacement: passo 15, imagem 1 %32
    • Use a T8 torx screwdriver to remove the seven, 6.8mm long screws from the metallic panel.
    Pergunte ao FixBot
    Comentar
  16. Macintosh PowerBook 165c Keyboard Replacement: passo 16, imagem 1 %32
    • Remove the keyboard by lifting it vertically away from the main body of the computer.
    Pergunte ao FixBot
    Comentar
Conclusão
Adam
Membro desde: 10/12/11
1 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-3, Regan Fall 2011 Membro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 2
Últimos 7 dias: 12
Últimos 30 dias: 43
Ao todo: 1,227
