Ir para o conteúdo principal
Macintosh PowerBook 165c Display Replacement
O que você precisa
  1. Macintosh PowerBook 165c Display Replacement, Display: passo 1, imagem 1 %32
    • Orientate the computer right side up and open the display case to reveal the display.
    • Use a plastic opening tool to remove the two small plastic plugs located on the display case just below the display.
    Pergunte ao FixBot
    Comentar
  2. Macintosh PowerBook 165c Display Replacement: passo 2, imagem 1 %32
    • Use a T8 torx screwdriver to remove the two, 7.7mm long screws that were revealed by removing the plastic plugs.
    • Twist counterclockwise to remove the screw.
    • Caution: Once the screws are removed, the display is only held by two screws. Handle delicately.
    Pergunte ao FixBot
    Comentar
  3. Macintosh PowerBook 165c Display Replacement: passo 3, imagem 1 %32
    • Grip the two bottom corners of the plastic display cover and gently pull towards yourself so that the display cover rotates about the top of the display case.
    • The display cover should release from top.
    • Remove the display case.
    Pergunte ao FixBot
    Comentar
  4. Macintosh PowerBook 165c Display Replacement: passo 4, imagem 1 %32
    • Locate the black connector on the right of the display. The connector can be identified by the pink, light blue, and white wires protruding from its side.
    • Remove the black connector from the circuit board by pulling it away from its adapter.
    Pergunte ao FixBot
    Comentar
  5. Macintosh PowerBook 165c Display Replacement: passo 5, imagem 1 %32
    • Using a T8 torx screwdriver, remove the four, 10.8mm long screws from the corners of the display.
    • Caution: The display is no longer supported and must be handled with care.
    Pergunte ao FixBot
    Comentar
  6. Macintosh PowerBook 165c Display Replacement: passo 6, imagem 1 %32
    • Carefully tilt the display downwards and rest it on the keyboard.
    Pergunte ao FixBot
    Comentar
  7. Macintosh PowerBook 165c Display Replacement: passo 7, imagem 1 %32 Macintosh PowerBook 165c Display Replacement: passo 7, imagem 2 %32 Macintosh PowerBook 165c Display Replacement: passo 7, imagem 3 %32
    • Locate the orange ribbon cable on the back of the display.
    • Open the white tab fastener by pulling it outward.
    • Remove the orange ribbon cable by gently pulling it away from the opened tab fastener.
    • The display is now free.
    Pergunte ao FixBot
    Comentar
Conclusão
Uma outra pessoa concluiu este guia.
Jason
Membro desde: 10/12/11
110 Reputação
Autoria de 4 guias
Equipe
Cal Poly, Team 6-3, Regan Fall 2011 Membro de Cal Poly, Team 6-3, Regan Fall 2011
CPSU-REGAN-F11S6G3
4 Membros
Autoria de 12 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 11
Últimos 30 dias: 45
Ao todo: 2,912
