Ir para o conteúdo principal
Macbook (Pro) Optical/CD Drive Disassembly
    1. Macbook (Pro) Optical/CD Drive Disassembly, Optical/CD Drive: passo 1, imagem 1 %32
      • This is the optical drive once it has been removed from the computer. I think there might be some screws that I removed prior to taking this picture.
      Pergunte ao FixBot
      Comentar
    2. Macbook (Pro) Optical/CD Drive Disassembly: passo 2, imagem 1 %32 Macbook (Pro) Optical/CD Drive Disassembly: passo 2, imagem 2 %32 Macbook (Pro) Optical/CD Drive Disassembly: passo 2, imagem 3 %32
      • There is aluminium foil sticky tape that covers how the drive is split. You can see how the drive is split after having removed the tape. Now that you know how it is split you can probably make a nicer rip than me.
      Pergunte ao FixBot
      Comentar
    3. Macbook (Pro) Optical/CD Drive Disassembly: passo 3, imagem 1 %32
      • If I remember correctly, the aluminium and hinges held the cover on. With the aluminium off you can now enter deeper into the drive.
      Pergunte ao FixBot
      Comentar
Conclusão
Uma outra pessoa concluiu este guia.
forhereyesonly
Membro desde: 10/22/10
620 Reputação
Autoria de 3 guias
1Comentário do guia
Thanks for posting this.
matthewkiernan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 22
Últimos 30 dias: 101
Ao todo: 2,113
