Introdução
When replacing your hard drive, you must transfer the Torx screws from the old drive to the new one.
O que você precisa
With the case closed, place the Unibody top-side down on a flat surface.
Depress the grooved side of the access door release latch enough to grab the free end. Lift the release latch until it is vertical.
Remove the single Phillips screw securing the hard drive bracket to the upper case.
Remove the two T6 Torx screws from each side of the hard drive (four screws total).
431 outras pessoas executaram este guia.
8Comentários do guia
Very easy and worth the upgrade
The model A1278 in front of me doesn't look like the above. It has 10 screws holding a single piece base onto the body, and not a single quick-release catch in sight. The battery bay looks different as well, but removing the HDD is just as easy.
That is because you are looking at a MacBook Pro A1278, not the MacBook Unibody. Apple made the regular MacBook in an aluminum enclosure in 2008 and the following aluminum model was changed to be called the MacBook Pro.
