Ir para o conteúdo principal
MacBook Pro 16" 2019 Lower Case Replacement
O que você precisa
  1. MacBook Pro 16" 2019 Lower Case Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 16" 2019 Lower Case Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 16" 2019 Lower Case Replacement, Remove lower case screws: passo 2, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement, Remove lower case screws: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Completely power off and unplug your MacBook Pro before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove six screws securing the lower case, of the following lengths:
    • Four 3.7 mm screws
    • Two 7.3 mm screws
    • Note how the screws come out at a slight angle—you must reinstall them the same way.
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 16" 2019 Lower Case Replacement, Unclip lower case: passo 3, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement, Unclip lower case: passo 3, imagem 2 %32
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle just enough to open a small gap under the lower case.
  4. MacBook Pro 16" 2019 Lower Case Replacement: passo 4, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 4, imagem 2 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 4, imagem 3 %32
    • Slide the corner of an opening pick into the gap you just created underneath the lower case.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  5. MacBook Pro 16" 2019 Lower Case Replacement: passo 5, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 5, imagem 2 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  6. MacBook Pro 16" 2019 Lower Case Replacement: passo 6, imagem 1 %32
    • Lift the front edge of the lower case (the side opposite the display hinge) enough to slide your fingertips underneath and get a good grip on it.
    • Two additional hidden clips near the middle of the cover should pop free at this point, if they haven't already.
    • Don't lift more than an inch or so, and don't try to remove the lower case yet.
  7. MacBook Pro 16" 2019 Lower Case Replacement: passo 7, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 7, imagem 2 %32 MacBook Pro 16" 2019 Lower Case Replacement: passo 7, imagem 3 %32
    • Pull firmly to slide the lower case towards the front edge of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This may require a lot of force.
  8. MacBook Pro 16" 2019 Lower Case Replacement, Remove lower case: passo 8, imagem 1 %32 MacBook Pro 16" 2019 Lower Case Replacement, Remove lower case: passo 8, imagem 2 %32 MacBook Pro 16" 2019 Lower Case Replacement, Remove lower case: passo 8, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and align the sliding clips near the display hinge. Press down and slide the cover toward the hinge. It should stop sliding as the clips engage.
    • When the sliding clips are fully engaged and the lower case looks correctly aligned, press down firmly on the lower case to engage the four hidden clips underneath. You should feel and hear them snap into place.
Conclusão
48 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
160.407 Reputação
Autoria de 439 guias
Equipe
iFixit Membro de iFixit
Staff
124 Membros
Autoria de 24.282 guias
2Comentários do guia
What function does the black sheet/mat/? provide for the computer? Is it necessary?
steve liethen - Responder Compartilhar
Mijn schroefjes zijn helemaal door gedraaid wat kan ik hier aan doen?
Stan - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 44
Últimos 7 dias: 254
Últimos 30 dias: 1,202
Ao todo: 91,919
