Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Remove the following ten screws securing the lower case to the upper case:
Three 13.5 mm (14.1 mm) Phillips screws.
Seven 3 mm Phillips screws.
Using both hands, lift the lower case near the vent to pop it off two clips securing it to the upper case.
Remove the lower case and set it aside.
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
Remove the two 7.4 mm Tri-point screws securing the battery to the upper case.
Carefully peel the battery warning label rounded end (the one without glue) off the upper case between the battery and the optical drive to reveal an additional Tri-point screw.
Remove the last 7.4 mm Y0 Tri-point screw securing the battery to the upper case.
Use the attached plastic pull tab to remove the battery from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
244 outras pessoas executaram este guia.
37 comentários
MAJOR WARNING: this will probably NOT WORK. Sure, you can replace the battery easily enough. But there are MANY reports of Mac OS X not recognizing the new battery, no matter what you do. In my case I've had to put the old, swollen battery back. When I try to use the new one, it installs and connects perfectly, but Mac OS X spends all its time trying to find the battery. The laptop is practically useless because the system resources are consumed with trying to find the battery that it cannot see. Word to the wise—think 3 times before you try this.
It sounds like you purchased a faulty or poorly made battery. There are many out there ranging from $25 to over $100. You definitely get what you pay for when it comes to laptop batteries - and it is always a bit of a crapshoot with anything that is not OEM. The Egoway on Amazon worked well for me. About $75 - has good reviews and comes with a 1.5yr warranty.
Works as it should. No problems with the new battery. The only thing which is different is, that in my MacBook Pro mid 2012 are Phillipps #000 and Y0 Tri Wing screws instead the above listet.
