Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Remova os seguintes parafusos pentalobe P5 que prendem a estrutura inferior ao MacBook Pro:
Oito de 3,0 mm
Dois de 2,3 mm
Este passo não foi traduzido. Ajude a traduzi-lo
Insert the flat end of a spudger underneath the rubber heat sink cover on the right fan.
Slide the spudger underneath the length of the cover, releasing the adhesive.
Lift the cover and rotate it off of the heat sink.
In the same manner described above, release the adhesive and flip back the heat sink cover on the left fan.
Remove the following ten screws securing the heat sink to the logic board:
Two 2.4 mm T5 Torx screws
Six 3.4 mm T5 Torx screws
One 5.2 mm Raised Head T5 Torx screw
One 3.5 mm T5 Torx screw
Grasping the heat sink from one side, lift the heat sink off of the MacBook Pro, pulling it free from the computer.
40 outras pessoas executaram este guia.
7 comentários
Hello everybody!!! I tried to follow this guide... I removed the bottom case, no problem... but when it was the time to remove the upper 2.4mm T5 torn screw... it stripped and now i cannot remove it! How can i remove that screw?
And if this is not enough one of the 3mm pentalobe screw of the bottom stripped too! so what can i do?!? please help me!
Sorry for my bad english
I'm sorry to hear that! Try checking out this stripped screw guide and reading through this Answers post. Hope this helps with your repair!
I won't call this moderate but rather easy instead, seems like ifixit expect that easy is something you just unplug without even open the computer
