Ir para o conteúdo principal
MacBook Pro 15" Core Duo Model A1150 RAM Replacement
O que você precisa
  1. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, Battery: passo 1, imagem 1 %32
    • Use your fingers to push both battery release tabs away from the battery, and lift the battery out of the computer.
    Pergunte ao FixBot
    Comentar
  2. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, Memory Door: passo 2, imagem 1 %32
    • Remove the three identical Phillips screws from the memory door.
    • Make sure to record which sets of screws came from where. This will help when re-assembling.
    Pergunte ao FixBot
    Comentar
  3. MacBook Pro 15" Core Duo Model A1150 RAM Replacement: passo 3, imagem 1 %32
    • Lift the memory door up enough to get a grip on it, and slide it toward you, pulling it away from the casing.
    Pergunte ao FixBot
    Comentar
  4. MacBook Pro 15" Core Duo Model A1150 RAM Replacement, RAM: passo 4, imagem 1 %32
    • Release the tabs on each side of the RAM chip at the same time. These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    Pergunte ao FixBot
    Comentar
  5. MacBook Pro 15" Core Duo Model A1150 RAM Replacement: passo 5, imagem 1 %32
    • Pull the chip directly out from its connector.
    • If there are two RAM chips installed, repeat the above procedure for the second chip.
    Pergunte ao FixBot
    Comentar
Conclusão
65 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 636 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 16
Últimos 30 dias: 76
Ao todo: 63,657
