Ir para o conteúdo principal
MacBook Pro 14" 2021 Fan Assembly Replacement
O que você precisa
  1. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the lower case: passo 1, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the lower case: passo 1, imagem 2 %32
    Ferramenta utilizada nesse passo:
    FixMat
    $36.95
    Comprar
    • Completely power off and unplug your MacBook Pro before you start. Close the screen and flip the entire laptop upside-down.
    • Use a P5 Pentalobe driver to remove eight screws securing the lower case:
    • Four 9.3 mm screws
    • Four 5 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 14" 2021 Fan Assembly Replacement, Unclip the lower case: passo 2, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unclip the lower case: passo 2, imagem 2 %32
    • Press a suction handle into place near the front edge of the lower case, between the screw holes.
    • Pull up on the suction handle to create a small gap under the lower case.
  3. MacBook Pro 14" 2021 Fan Assembly Replacement, Release the right clips: passo 3, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the right clips: passo 3, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the right clips: passo 3, imagem 3 %32
    • Insert an opening pick into the gap you just created.
    • Slide the opening pick around the nearest corner and then halfway up the side of the MacBook Pro.
    • This releases the first of the hidden clips securing the lower case. You should feel and hear the clip pop free.
  4. MacBook Pro 14" 2021 Fan Assembly Replacement, Release the left clips: passo 4, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the left clips: passo 4, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the left clips: passo 4, imagem 3 %32
    • Repeat the previous step on the other side, using an opening pick to to release the second clip.
  5. MacBook Pro 14" 2021 Fan Assembly Replacement, Release the sliding clips: passo 5, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the sliding clips: passo 5, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the sliding clips: passo 5, imagem 3 %32
    • Sliding clips along the back edge of the MacBook further secure the lower case. Separating these clips may require a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Firmly pull the lower case away from the back edge, one corner at a time, to disengage the sliding clips.
    • Keep the lower case flat to the MacBook. Don't pull upward until it's completely separated.
  6. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the lower case: passo 6, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the lower case: passo 6, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the lower case: passo 6, imagem 3 %32
    • Remove the lower case.
    • To reinstall the lower case:
    • Lay it down and align the sliding clips with the back edge of the MacBook. Press down on the lower case and slide it toward the back edge to engage the clips.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push.
    • Once the back corners of the lower case are secured and flush with the frame, press down along the middle of the lower case to engage the four remaining clips.
    • You'll hear and feel each clip snap into place.
  7. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery board: passo 7, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery board: passo 7, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery board: passo 7, imagem 3 %32
    • Peel back any tape covering the battery board data cable connector on the logic board.
  8. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 8, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 8, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the battery board data cable.
  9. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 9, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 9, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket on the logic board.
  10. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the trackpad cable bracket: passo 10, imagem 1 %32
    • While your MacBook uses some Torx Plus screws, standard Torx bits work. Make sure to apply constant, downward force to avoid stripping.
    • Use a T3 Torx driver to remove the two 2.1 mm‑long 3IP Torx Plus screws securing the trackpad cable bracket to the logic board.
  11. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the trackpad cable bracket: passo 11, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the trackpad cable bracket: passo 11, imagem 2 %32
    Comprar
    • Use tweezers, or your fingers, to remove the trackpad cable bracket.
  12. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the trackpad cable: passo 12, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the trackpad cable: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry up and disconnect the trackpad cable's press connector secured to the logic board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Don't press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  13. MacBook Pro 14" 2021 Fan Assembly Replacement, Reposition the trackpad cable: passo 13, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Reposition the trackpad cable: passo 13, imagem 2 %32
    • The trackpad cable is lightly adhered to the frame.
    • Peel the trackpad cable away from the device, making sure to separate the adhesive.
  14. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery board: passo 14, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery board: passo 14, imagem 2 %32
    • Peel back any tape covering the battery board data cable connector under the large pancake screw.
  15. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 15, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 15, imagem 2 %32
  16. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 16, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 16, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket on the battery board.
  17. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the data cable: passo 17, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the data cable: passo 17, imagem 2 %32
    • The battery board data cable is lightly adhered to the device.
    • Slide blunt nose tweezers under areas with adhesive to separate the cable from the device.
    • Remove the battery board data cable.
  18. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the battery connector: passo 18, imagem 1 %32
    • Use a T5 Torx driver to remove the 3.8 mm 5IP Torx Plus wide-head screw securing the battery power connector.
  19. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery connector: passo 19, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery connector: passo 19, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the battery connector: passo 19, imagem 3 %32
    • Use the flat end of your spudger to lift the battery connector away from the battery board, disconnecting the battery.
    • Lift the connector high enough that it doesn't accidentally make contact during the repair, but no more than 45 degrees to prevent damaging its hinge.
    • For added safety, place a barrier, such as a piece of a playing card, between the connector and board.
  20. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the antenna bar's connector bracket: passo 20, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the antenna bar's connector bracket: passo 20, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the three 2.1 mm screws securing the antenna board bracket and coaxial cable cover to the frame.
  21. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 21, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 21, imagem 2 %32
    Comprar
    • Use tweezers, or your fingers, to remove the cover on top of the antenna bar's coaxial cables.
  22. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the antenna bar: passo 22, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the antenna bar: passo 22, imagem 2 %32
    • Use the tip of a spudger to pry up and disconnect the antenna bar's coaxial cable.
    • Repeat for the two other cables.
    • During reassembly, these can be tricky to reconnect. Hold each connector in place over its socket and press down with the flat end of a spudger. The connector should snap into place.
  23. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the screen cable covers: passo 23, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the screen cable covers: passo 23, imagem 2 %32
    • Use a T3 Torx driver to remove the four 2.1 mm screws securing the screen cable covers.
  24. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the screen cable covers: passo 24, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the screen cable covers: passo 24, imagem 2 %32
    • Use tweezers, or your fingers, to remove the two screen cable covers from the logic board.
  25. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the screen cables: passo 25, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the screen cables: passo 25, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the screen cables: passo 25, imagem 3 %32
    • Use the flat end of a spudger to pry up and disconnect the right-most screen cable press connectors secured to the logic board.
  26. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 26, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 26, imagem 2 %32
    • Repeat the previous disconnection process for the remaining press connector at the top left of the logic board.
    • Don't pry against the surface-mounted components near the press connector.
  27. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 27, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 27, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 27, imagem 3 %32
    • Peel back any tape covering the microphone cable connector.
  28. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 28, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 28, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the microphone cable.
  29. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 29, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 29, imagem 2 %32
    • Disconnect the microphone cable by sliding it out from its socket on the logic board.
  30. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the right-side cable covers: passo 30, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the right-side cable covers: passo 30, imagem 2 %32
    • Use a T3 Torx driver to remove the nine 2.1 mm screws securing the right cable covers to the frame:
  31. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the right cable covers: passo 31, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the right cable covers: passo 31, imagem 2 %32
    • Use tweezers, or your fingers, to remove the five right cable covers.
  32. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 32, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 32, imagem 2 %32
    • Peel back any tape covering the right speaker cable.
  33. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 33, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 33, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right speaker cable.
  34. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 34, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 34, imagem 2 %32
    • Disconnect the right speaker cable by sliding it out from its socket on the logic board.
  35. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the headphone jack: passo 35, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the headphone jack: passo 35, imagem 2 %32
    • Use a spudger to pry up and disconnect the headphone jack's press connector.
  36. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the right USB-C ports: passo 36, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the right USB-C ports: passo 36, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the right USB-C ports: passo 36, imagem 3 %32
    • Use a spudger to pry up and disconnect the right USB-C ports' press connectors.
  37. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the MagSafe port: passo 37, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the MagSafe port: passo 37, imagem 2 %32
    • Use a spudger to pry up and disconnect the MagSafe port's press connector.
  38. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the lid angle sensor cable: passo 38, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the lid angle sensor cable: passo 38, imagem 2 %32
    • Use a spudger to pry up and disconnect the lid angle sensor's press connector.
  39. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the left cable covers: passo 39, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the left cable covers: passo 39, imagem 2 %32
    • Use a T3 Torx driver to remove the four screws securing the left cable covers to the frame:
    • Two 2 mm screws
    • Two 2.1 mm screw
  40. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the left cable covers: passo 40, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the left cable covers: passo 40, imagem 2 %32
    • Use tweezers, or your fingers, to remove the two left cable covers.
  41. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the left speaker: passo 41, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the left speaker: passo 41, imagem 2 %32
    • Peel back any tape covering the left speaker cable.
  42. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 42, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 42, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the left speaker cable.
  43. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 43, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 43, imagem 2 %32
    • Disconnect the left speaker cable by sliding it out from its socket on the logic board.
  44. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the left USB-C port: passo 44, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the left USB-C port: passo 44, imagem 2 %32
    • Use a spudger to pry up and disconnect the left USB-C port's press connector.
  45. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the Touch ID sensor: passo 45, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the Touch ID sensor: passo 45, imagem 2 %32
    • Use a spudger to pry up and disconnect the Touch ID sensor's press connector near the top left of the device.
    • The Touch ID sensor cable is adhered to the frame. If the adhesive doesn't separate when you disconnect the press connector, slide an opening pick under the cable to separate it.
  46. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the keyboard: passo 46, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the keyboard: passo 46, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the keyboard: passo 46, imagem 3 %32
  47. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 47, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 47, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 47, imagem 3 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connectors for the keyboard cables.
  48. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 48, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 48, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 48, imagem 3 %32
    • Disconnect the keyboard and keyboard backlight cables by sliding them out from their sockets on the logic board.
  49. MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the fans: passo 49, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the fans: passo 49, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Disconnect the fans: passo 49, imagem 3 %32
    • Peel back any tape covering the right fan cable connector.
  50. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 50, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 50, imagem 2 %32
    • Use a spudger to gently pry up the locking flap on the ZIF connector for the right fan cable.
  51. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 51, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 51, imagem 2 %32
    • Disconnect the right fan cable by sliding it out from its socket on the logic board.
  52. MacBook Pro 14" 2021 Fan Assembly Replacement, Reposition the right fan cable: passo 52, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Reposition the right fan cable: passo 52, imagem 2 %32
    • The right fan cable is lightly adhered to the logic board.
    • Pull the fan cable away from the logic board with tweezers to separate the adhesive.
    • The fan cables are incredibly delicate and prone to tearing; use caution when bending them with tools.
  53. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 53, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 53, imagem 2 %32
    • Repeat the previous disconnection and reposition procedure for the left fan.
  54. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 54, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 54, imagem 2 %32
    • Remove the four black screw covers from the logic board.
  55. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the logic board: passo 55, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the logic board: passo 55, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the logic board: passo 55, imagem 3 %32
    • Use a T5 Torx driver to remove the 11 screws securing the logic board:
    • Four 3.6 mm screws
    • Two 4.5 mm screws
    • Two 5.2 mm screws
    • Two 3.8 mm screws
    • One 3.9 mm screw
  56. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 56, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 56, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 56, imagem 3 %32
    • Use a T6 Torx driver to remove the three screws securing the logic board:
    • Two 4.7 mm screws
    • One 5.7 mm screw
  57. MacBook Pro 14" 2021 Fan Assembly Replacement, Release the logic board's clips: passo 57, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Release the logic board's clips: passo 57, imagem 2 %32
    • Insert a spudger between the right side of the logic board and the frame.
    • Pry up with the spudger to release the logic board from its clips.
  58. MacBook Pro 14" 2021 Fan Assembly Replacement: passo 58, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement: passo 58, imagem 2 %32
    • Insert a spudger between the bottom of the logic board and the frame.
  59. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the logic board: passo 59, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the logic board: passo 59, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the logic board: passo 59, imagem 3 %32
    • Gently lift up the logic board by its right side to release it from its alignment pegs.
    • If it feels like it's not coming out, check that all the cables are disconnected.
    • Pull the logic board away from the left side of the device to separate the HDMI and SDXC ports from their slots in the frame.
    • Remove the logic board.
  60. MacBook Pro 14" 2021 Fan Assembly Replacement, Reassembly information: passo 60, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Reassembly information: passo 60, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Reassembly information: passo 60, imagem 3 %32
    • During reassembly, perform the following:
    • Make sure all 17 connectors are above the logic board before securing it back into the frame.
    • If you're having trouble positioning the connectors, use tape to keep them out of the way.
    • Hold the rubber spacers out of the way so the fins can drop into their recesses.
    • When reinstalling the logic board, insert the left side first to reposition the HMDI and SDXC ports.
    • Use your fingers to slightly compress the HDMI port to fit it into its recess. Otherwise, the logic board won't sit correctly.
  61. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the screw covers: passo 61, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the screw covers: passo 61, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the screw covers: passo 61, imagem 3 %32
    • Use a spudger to remove the four screw covers.
  62. MacBook Pro 14" 2021 Fan Assembly Replacement, Separate the adhesive: passo 62, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Separate the adhesive: passo 62, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Separate the adhesive: passo 62, imagem 3 %32
    • Both of the fans' cables are lightly adhered to the frame.
    • Insert the tip of an opening pick between the fan's cable and the frame.
    • Slice with the pick along the edges of the cable to separate the adhesive.
  63. MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the fans: passo 63, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Unfasten the fans: passo 63, imagem 2 %32
    • Remove the eight screws securing the fans to the frame:
    • Six 3.3 mm T3 Torx screws
    • Two 3 mm T5 Torx screws
  64. MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the fans: passo 64, imagem 1 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the fans: passo 64, imagem 2 %32 MacBook Pro 14" 2021 Fan Assembly Replacement, Remove the fans: passo 64, imagem 3 %32
    • Remove the fans.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our MacBook Pro 14" 2021 Answers community for help.
Uma outra pessoa concluiu este guia.
Alex Diaz-Kokaisl
Membro desde: 01/16/22
124.993 Reputação
Autoria de 582 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 136
Autoria de 17.410 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 12
Últimos 7 dias: 58
Últimos 30 dias: 237
Duração total: 5,028
