Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace a blown subwoofer or right speaker.
O que você precisa
Remove the following ten screws:
Three 14.4 mm Phillips #00 screws
Three 3.5 mm Phillips #00 screws
Four 3.5 mm shouldered Phillips #00 screws
Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable connector up from its socket on the logic board.
Use a plastic opening tool or another thin prying object to carefully pry the right speaker up from the adhesive securing it to the upper case.
Pry up along the edge of the right speaker until it is separated from the upper case.
21 outras pessoas executaram este guia.
5 comentários
Killer detailed instructions!! However, it’s clear to me that this is going to the shop for repair - way over my head !!! NICE job, though!!
I was bloody terrified the whole time but it worked. My audio no longer clips at certain frequencies. Also I feel like a god and my household is quote “very impressed.” Bless your soul Philip!!!!
he is an amazing guy!!!!
lle -
hi amazing instructions! super easy to follow… I was able to do this in class with no distractions vert easily. My classmate Vitor fixed this with no problem in exactly 3.47 minutes…. i timed it! Thank you for your service you sir are a saint.. and saved my life. Take care Philip hope you get more badges! fank ya vary much.
