Ir para o conteúdo principal
MacBook Pro 13" Unibody Early 2011 RAM Replacement
O que você precisa
  1. MacBook Pro 13" Unibody Early 2011 RAM Replacement, Lower Case: passo 1, imagem 1 %32
    • Remove the following ten screws:
    • Three 14.4 mm Phillips #00 screws
    • Three 3.5 mm Phillips #00 screws
    • Four 3.5 mm shouldered Phillips #00 screws
    • When replacing the small screws, align them perpendicular to the slight curvature of the case (they don't go straight down).
    Pergunte ao FixBot
    Comentar
  2. MacBook Pro 13" Unibody Early 2011 RAM Replacement: passo 2, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 RAM Replacement: passo 2, imagem 2 %32
    • Use your fingers to pry the lower case away from the body of the MacBook near the vent.
    • Remove the lower case.
    Pergunte ao FixBot
    Comentar
  3. MacBook Pro 13" Unibody Early 2011 RAM Replacement, Battery Connection: passo 3, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 RAM Replacement, Battery Connection: passo 3, imagem 2 %32
    • Use the edge of a spudger to pry the battery connector upwards from its socket on the logic board.
    • It is useful to pry upward on both short sides of the connector to "walk" it out of its socket. Be careful with the corners of the connectors, they can be easily broken off.
    Pergunte ao FixBot
    Comentar
  4. MacBook Pro 13" Unibody Early 2011 RAM Replacement: passo 4, imagem 1 %32
    • Bend the battery cable slightly away from its socket on the logic board so it does not accidentally connect itself while you work.
    Pergunte ao FixBot
    Comentar
  5. MacBook Pro 13" Unibody Early 2011 RAM Replacement, RAM: passo 5, imagem 1 %32 MacBook Pro 13" Unibody Early 2011 RAM Replacement, RAM: passo 5, imagem 2 %32
    • Pull the two RAM retaining arms away from the center of the RAM chip.
    • The RAM chip should "pop" up slightly from its socket.
    Pergunte ao FixBot
    Comentar
  6. MacBook Pro 13" Unibody Early 2011 RAM Replacement: passo 6, imagem 1 %32
    • Pull the RAM stick out of its socket.
    • Repeat this process to remove the second RAM chip.
    Pergunte ao FixBot
    Comentar
Conclusão
354 outras pessoas executaram este guia.
11Comentários do guia
What kind of ram should I buy? DDR2 or DDR3?
Jason Moon - Responder Compartilhar
It takes only DDR-3 RAM.
oakdragon12 - Responder Compartilhar
Is a 8gb early 2011 macbook pro maxed out, or can I upgrade to 16?
I'm asking because I read in http://www.crucial.com/store/mpartspecs.... that it can actually take 16gb. Thanks!
C Eyzag - Responder Compartilhar
Yup! I upgraded to a 16 GB DDR3 Corsair mac memory kit from Newegg and it works like a charm. I got this kit: https://www.newegg.com/Product/Product.a...
screenshots below:
http://i.imgur.com/IqEbFES.jpg
http://i.imgur.com/a2azyuV.jpg
Drew Dittmann - Responder Compartilhar
Question - my MBP currently has 4GB RAM. Is there a 2nd RAM slot that will allow me to increase my RAM by adding 4GB or 8GB. Or do I need to replace the current 4GB with a new 8GB module?
Steve K - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 4
Últimos 7 dias: 46
Últimos 30 dias: 313
Ao todo: 321,631
