Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Use this guide to replace a touchbar on an A2289 Macbook Pro 13" Mid 2020.
Be mindful to keep all screws and brackets organized. This will keep from damaging sensitive components by accidently screwing the wrong size screw in.
O que você precisa
To begin, we will need to remove 6 total screws
2x 6.9mm
2x 5.5mm
2x 3.5mm
Ferramenta utilizada nesse passo:Heavy-Duty Suction Cups (Pair)$14.95
After the screws are removed, grab a suction cup. We used iFixit's Heavy Duty Suction cup.
Place the suction cup towards the bottom of the Macbook
Pull up on the suction cup; Creating about 0.15in worth of space from the panel and the Macbook.
Ferramenta utilizada nesse passo:iFixit Opening Picks (Set of 6)$4.99
While creating the gap between the Macbook and the back panel, insert an opening pick into the gap about 0.2in.
Move the pick towards the left side of the Macbook and around the corner edge.
Bring the pick up towards the top of the Macbook
Once you reach about the middle of the Macbook, you should hear a click. This is good! You have now unhooked part of the back panel.
Insert your fingers in-between the back panel and Macbook and pry upwards to unhook the middle hook keeping the back panel connected to the Macbook
Grip the back panel with one hand
Grip the Macbook with the other hand
And pull the left side of the back panel AWAY from the HINGE side of the Macbook
Repeat this with the right side of the Macbook
Ferramenta utilizada nesse passo:Tweezers$3.99
Locate the small flex cable covering the battery terminal
Take a pair of tweezers in one hand and pull up on the plastic flap
Take the hook end of a Halberd Spudger in the other hand and gently pry up the retaining flap on the battery cable ZIF socket
Locate the left LCD screen spring
Remove 2x 4.1mm screws securing the spring to the Macbook
Locate the right LCD screen spring
Locate the antenna towards the top of the Macbook
Remove 12x 1.2mm screws securing the antenna to the Macbook
Locate the LCD board towards the top of the Macbook
Remove 4x 3.4mm screws securing the LCD board to the Macbook and to the antenna
You should now be able to remove the antenna from the Macbook.
Gently pry & pull away the antenna cable from the Macbook while routing it's cable through their hole. Take care here, as the antenna sockets can be ripped from the board easily.
Locate the left LCD screen hinge
Remove 2x 4.5mm screws that secure the hinge to the Macbook
Locate the right LCD screen hinge
Place Macbook at the edge of your work bench and let the screen overhang
Locate and remove the remaining 2x 4.5mm screws securing the 2 hinges to the Macbook
Bend the LCD screen slightly towards you
Gently pry up the LCD screen from the Macbook, while guiding the hinges out of their divots
Locate 8x flex cables connected the logic board
For each flex cable, pull up on their plastic flap with a pair of tweezers
Take the hook end of a Halberd Spudger and gently pry up the retaining flap on the ZIF socket of each cable
Take your tweezers and pull on the plastic cover to pull each cable away from the ZIF socket to remove the flex cable from it's socket
If any of the plastic flaps break off don't worry! You can use a combination of your spudger and tweezers to gently pull out the flex cable from it's respective socket
Locate and remove 5x Logic Board Screws
During Reassembly: It may be difficult to screw the top left logic board screw back in. If you are finding it hard to do this, take the 1.4mm screw that we removed to remove the power button bracket and screw it into the top left logic board screw. Afterwards, take the now "cyborg" screw and screw it into the logic board.
Ferramenta utilizada nesse passo:Halberd Spudger$2.99
Take the hook end of your Halberd Spudger and gently pry up the top left corner of the logic board
Now remove the logic board from the Macbook
Locate the touchbar flex cable mess towards the top right of the Macbook
You will be removing a total of 3 screws to release this cabled mess from the frame
2x 2.4mm
One of these are "hidden" by a small pad. Take a pair of tweezers and remove this pad to access the screw head
1x 1.7mm
These brackets that keep the cabled mess down and attached to the frame are adhered to the cabling
Remove these brackets from the flex cabling mess
Ferramenta utilizada nesse passo:iFixit Adhesive Remover$19.99
There are 2 methods that we can take towards removing this annoying touchbar. We went ahead and performed what we thing is the harder method.
Method 1: Take 2 tweezers or handles and wrap very thin wire around them. Then pull the wire underneath the touchbar LCD gently while being careful not to damage the keyboard
Method 2: What we did. Remove the touchbar digitizer first by prying it up and off the touchbar LCD. Then use a combination Adhesive Remover and a Technician's Razor Set to remove the touchbar LCD.
Take a Halberd Spudger and insert the knife end right underneath the plastic of the digitizer
Run the Halberd Spudger along the edge of the touchbar digitizer
The digitizer should separate surprisingly easy.
Feed the Touchbar digitizer cable through the hole and remove the digitizer
Ferramenta utilizada nesse passo:Technician's Razor Set$14.99
Take a technician's knife and start prying away the LCD of the touchbar.
To reassemble your device, follow these instructions in reverse order. Follow this guide to reinstall the new touchbar properly.
We here at Smart Cloud hope your project goes smoothly and without a hitch. However, things happen and we want to make sure you know we are here to help if needed. You may contact us if needed as we can provide support or repair options per request. Good luck and have fun.
3 outras pessoas executaram este guia.
3 comentários
Bonjour, excellent tuto. Bien réalisé grâce aux outils MAKO de ifixit.
Etape 31, il faut utiliser T5. Les 3 vis n'ont pas toutes la même longueur.
J'ai cassé un connecteur sur la carte : est ce que je peux mettre de la colle chaude pour tenir la nappe ?
Encore merci pour cette précieuse aide
