Ir para o conteúdo principal
MacBook Pro 13" Touch Bar 2018 Left fan Replacement
O que você precisa
  1. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • 'sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command (typed into Terminal, as shown above):
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the pentalobe screws: passo 2, imagem 1 %32
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Four 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Open a gap using a suction cup: passo 3, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Open a gap using a suction cup: passo 3, imagem 2 %32
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight gap between the lower case and the chassis.
  4. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: passo 4, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: passo 4, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Separate the clips: passo 4, imagem 3 %32
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 5, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 5, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 6, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 6, imagem 3 %32
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 7, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 7, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 7, imagem 3 %32
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • Pull first at one corner, then the other.
    • Pull to the side—not up.
    • This can require a lot of force.
  8. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the lower case: passo 8, imagem 1 %32
    • Remove the lower case.
  9. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Uncover the battery connector: passo 9, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Uncover the battery connector: passo 9, imagem 2 %32
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 10, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 10, imagem 2 %32
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 11, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  12. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 12, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 12, imagem 2 %32
    • Fold the battery board data cable to the side and out of the way.
  13. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 13, imagem 1 %32
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  14. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect the battery: passo 14, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect the battery: passo 14, imagem 2 %32
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  15. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Remove the trackpad connector screws: passo 15, imagem 1 %32
    • Use a T3 Torx driver to remove the two 1.8 mm screws securing the trackpad cable connector bracket.
  16. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 16, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Comprar
    • Remove the trackpad cable connector bracket with a pair of tweezers.
  17. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 17, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 17, imagem 2 %32
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  18. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect keyboard connector: passo 18, imagem 1 %32
    • Use a T3 Torx driver to remove the two screws.
    • Two T3 Torx Screws.
  19. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Left speaker cables: passo 19, imagem 1 %32
    • Carefully peel back the black tape to reveal the ZIF connector.
    • Unlatch the ZIF connector by flicking the arm on the connector upwards and carefully remove the cable from the connector by sliding it out.
    • Repeat this process with the newly revealed connector.
    • The two screws that are outlined in yellow are not relevant to this step and are marked on the board itself. For this step, yellow corresponds to the yellow rectangle in the image.
  20. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug left Thunderbolt ports: passo 20, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug left Thunderbolt ports: passo 20, imagem 2 %32
    • Once the screw have been removed carefully remove the metal shield.
    • Under the metal shield there is a connector, carefully unplug it.
  21. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: passo 21, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: passo 21, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Touch ID and Auxiliary port: passo 21, imagem 3 %32
    • Use a T4 Torx driver to remove the two screws.
    • Two T4 Torx screws.
    • Carefully remove the metal shield.
    • Under the metal shield you will find two connectors, carefully unclip them.
    • The second cable you will disconnect will be lightly adhered so carefully slide a plastic spudger under it and finally unplug it.
    • The adhered cable is very thin and delicate so don't rush it and take your time.
  22. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: passo 22, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: passo 22, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnecting the display connector: passo 22, imagem 3 %32
    • Use a T3 Torx driver to remove the four screws.
    • 4 T3 Torx screws.
    • Once the screws are removed carefully remove the metal shields.
    • Carefully unclip the connector.
  23. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Disconnect wifi and Bluetooth antennas: passo 23, imagem 1 %32
    • Disconnect the cables carefully with a plastic pry tool.
    • Be gentle, if too much force is applied it can take the board connector up with it.
  24. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: passo 24, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: passo 24, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch Bar cable 1: passo 24, imagem 3 %32
    • Remove the metal shield carefully.
    • Carefully unplug the connector.
  25. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Right speaker cable: passo 25, imagem 1 %32
  26. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, ZIF connector: passo 26, imagem 1 %32
  27. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Right Thunderbolt ports: passo 27, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Unplug Right Thunderbolt ports: passo 27, imagem 2 %32
  28. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: passo 28, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: passo 28, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Touch bar bracket / Flex: passo 28, imagem 3 %32
    • Use a T4 Torx driver to remove the screw.
    • T4 Torx screw.
  29. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Audio socket / Touch ID bracket: passo 29, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Audio socket / Touch ID bracket: passo 29, imagem 2 %32
    • Use a T3 Torx driver to remove the two 1.4mm screws securing the bracket.
    • Remove the bracket.
  30. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 30, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 30, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 30, imagem 3 %32
    • gently disconnect the audio socket flex cable with a spudger.
    • gently disconnect the Touch ID flex cable with a spudger.
  31. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: passo 31, imagem 1 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: passo 31, imagem 2 %32 MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Display cable: passo 31, imagem 3 %32
    • Use a T3 Torx driver to remove the two 2.4mm screws securing the display cable bracket.
    • Use a T3 Torx driver to remove the two 1.2mm screws securing the display cable bracket.
    • gently disconnect the flex cable with a spudger.
  32. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 32, imagem 1 %32
    • Use a T5 Torx driver to remove the six 2.2mm screws securing the logic board.
    • Use a T3 Torx driver to remove the three 1.9mm screws securing the logic board.
    • Use a T5 Torx driver to remove the two 2.3mm (3.7mm head) screws securing the heatsink.
  33. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 33, imagem 1 %32
    • Carefully lift up the logic board, make sure none of the connectors are connected, also make sure they aren't caught on the logic board.
  34. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 34, imagem 1 %32
    • Congratulations you have now removed your MacBook's LogicBoard
  35. MacBook Pro 13" Touch Bar 2018 Left fan Replacement, Left fan: passo 35, imagem 1 %32
    • Use a T3 Torx driver to remove the four 2.1mm screws securing the left fan board.
  36. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 36, imagem 1 %32
  37. MacBook Pro 13" Touch Bar 2018 Left fan Replacement: passo 37, imagem 1 %32
    • Remove the left fan.
Conclusão
David Fear
Membro desde: 09/08/11
4.510 Reputação
Autoria de 8 guias
Equipe
Pickle IT - Gadget Repair Membro de Pickle IT - Gadget Repair
Business
Membros da 2
Autoria de 19 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 7
Últimos 7 dias: 30
Últimos 30 dias: 93
Duração total: 247
