Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Ferramenta utilizada nesse passo:Magnetic Project Mat$19.95
Remova os seguintes dez parafusos que fixam a estrutura traseira à estrutura superior:
Dois parafusos P5 Pentalobe de 2,3 mm
Oito parafusos P5 Pentalobe de 3,0 mm
Este passo não foi traduzido. Ajude a traduzi-lo
Carefully remove the rubber fan bumper from the edge of the heat sink.
Use the flat end of a spudger to peel the four foam stickers off of the heat sink screws.
Remove the following screws securing the heat sink to the logic board:
Four 2.6 mm T5 screws
One 2.4 mm Phillips #000 screw
Use the tip of a spudger to push on either side of the the iSight camera cable connector to walk it out of its socket on the logic board.
Peel the iSight camera cable off the fan housing to fold it out of the way.
Use the tip of a spudger to flip the tab on the fan's ZIF connector.
Carefully pull the fan cable straight out of its socket.
Remove the following screws securing the fan to the upper case:
One 5.0 mm T5 Torx screw
Two 3.6 mm T5 Torx screws
Lift the end of the fan closest to the display hinge and remove the fan from the upper case.
Remove the two 2.1 mm T5 Torx screws securing the I/O board cable bracket to the logic board.
Remove the I/O board cable bracket.
Use the flat end of a spudger to pop the I/O board connector straight up off its socket on the logic board.
Lift the logic board end of the I/O board cable straight up to bend it out of the way.
Use the tip of a spudger to lift the right speaker connector straight up out of its socket on the logic board.
With the tip of a spudger, push on either side of the I/O board connector to walk it out of its socket on the logic board.
Use the flat end of a spudger to disconnect the keyboard backlight cable and bend it up out of the way of the logic board.
Grab the black plastic tab to flip the display cable connector open and pull it straight out of its socket on the logic board.
Carefully pull the DC-In board connector straight out of its socket on the logic board.
Wedge the flat end of a spudger under the left speaker cable near the connector and lift it straight up out of its socket and fold it out of the way.
Use the tip of a spudger to flip the retaining tab on the microphone cable ZIF connector.
Pull the microphone cable out of its socket on the logic board.
Use the tip of a spudger to flip the retaining tab on the ZIF connector.
Pull the keyboard cable straight out of its ZIF socket on the logic board.
Pull the trackpad ribbon cable straight out of its socket on the logic board.
Remove the five 3.5 mm T5 Torx screws securing the logic board to the upper case.
Lift the processor end of the logic board up slightly and pull it toward the fan recess to free the ports from the edge of the upper case.
Remove the logic board.
Remove the following screws securing the left speaker to the upper case:
One 5.7 mm T5 Torx screw
One 6.5 mm T5 Torx screw
One 3.8 mm T5 Torx screw
Lift the corner of the left speaker up and slide it toward the battery to remove it from the upper case.
Remove the single 3.7 mm T5 Torx screw securing the case-edge of the battery contact board.
Insert the tip of a spudger under the battery-side portion of the rubber microphone cable cover to detach the adhesive there.
Use the flat end of a spudger to wedge the battery contact board up slightly to allow room to extract the dual microphone assembly.
Remove the rubber microphone cover with a set of tweezers
Insert the tip of a spudger underneath the connector end of the microphone ribbon cable and slide it toward the screw post to free that half from the upper case.
Insert the tip of a spudger under the battery-side portion of the microphone ribbon cable and slide it toward the screw post to free it from the upper case.
Pull the dual microphone cable assembly up and toward the logic board recess to remove it from the upper case.
