Ir para o conteúdo principal
MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement
O que você precisa
  1. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Two 2.3 mm P5 Pentalobe screws
    • Eight 3.0 mm P5 Pentalobe screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  2. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the upper case and the lower case.
    • Gently pull the lower case away from the upper case.
  3. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 3, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 3, imagem 3 %32
    • During reassembly, gently push down the center of the lower case to reattach the two plastic clips.
    • The lower case is connected to the upper case at the center, with two plastic clips.
  4. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Battery Connector: passo 4, imagem 1 %32
    • Remove the plastic cover adhered to the battery contact board.
  5. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 5, imagem 1 %32
    • Remove the following screws securing the battery connector board to the logic board:
    • Two 2.8 mm T6 Torx screws
    • One 7.0 mm T6 Torx shouldered screw
  6. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 6, imagem 2 %32
    • Use tweezers to remove the small plastic cover located near the bottom right of the battery connector board.
  7. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 7, imagem 1 %32
    • Remove the wide head 6.4 mm T6 Torx screw securing the battery connector to the logic board assembly.
  8. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 8, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 8, imagem 2 %32
    • Carefully lift the battery connector board up off the logic board.
    • It is recommended to bend the battery cables just slightly, to keep the board suspended up above the logic board and out of the way.
    • Do not fold the board completely over, or crease the cables, as this may damage the battery.
  9. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Battery Contact Board: passo 9, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Battery Contact Board: passo 9, imagem 2 %32
    • Grasp the Interposer with tweezers.
    • An interposer is the name for an interface that links one electrical connection to another. In this repair, it is the board connecting the battery to logic board.
    • Lift the Interposer off the logic board and remove it.
    • Removing this board will ensure that the battery remains disconnected throughout your repair, preventing your computer from accidentally powering on. It's also a good idea to take it out so it doesn't fall out unexpectedly.
  10. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, I/O Board Data Cable: passo 10, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, I/O Board Data Cable: passo 10, imagem 2 %32
    • Use the flat end of a spudger to pry the right side of the I/O board data cable connector up off its socket on the I/O board.
    • When prying the I/O board data cable connector from its socket, make sure to pry the connector itself and not the socket. Prying the socket may cause irreversible damage to the I/O board.
  11. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 11, imagem 2 %32
    • Wedge the flat end of a spudger beneath the left side of the I/O board data cable connector.
    • Gently twist the spudger to disconnect the I/O board data cable connector from its socket on the logic board.
  12. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 12, imagem 1 %32
    • Lift and remove the I/O board data cable from the MacBook Pro.
  13. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Right Speaker: passo 13, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Right Speaker: passo 13, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Right Speaker: passo 13, imagem 3 %32
    • Use the flat end of a spudger to pry the SSD cable connector up from its socket on the logic board.
    • Move the SSD cable connector out of the way.
  14. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 14, imagem 2 %32
    • Wedge the pointed end of a spudger beneath the right speaker cable connector.
    • Gently pry the right speaker cable connector up off from its socket on the logic board.
    • Be sure you are prying up on the connector, not the socket itself.
  15. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 15, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 15, imagem 2 %32
    • Use a T5 Torx driver to remove the following screws securing the right speaker to the upper case:
    • One black 6.8 mm screw
    • One silver 6.3 mm screw
    • One black 4.9 mm screw
    • The silver screw (in the corner) may be covered with a foam pad. If so, use your tweezers to peel it up and remove it.
  16. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 16, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 16, imagem 2 %32
    • Lift and remove the right speaker out of the upper case.
    • If necessary, de-route the right speaker cable from its channel in the upper case.
  17. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Left Speaker: passo 17, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Left Speaker: passo 17, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Left Speaker: passo 17, imagem 3 %32
    • Use the flat end of a spudger to pry the headphone jack cable connector straight up off its socket on the logic board.
    • Gently bend the headphone jack cable to 90° up from the logic board.
    • Bending the headphone jack cable will allow you to disconnect the left speaker cable connector without having the headphone jack cable in the way.
  18. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 18, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 18, imagem 2 %32
    • Wedge the tip of a spudger beneath the left speaker cable connector.
    • Gently pry the left speaker cable connector up off from its socket on the logic board.
  19. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 19, imagem 1 %32
    • Use a T5 Torx driver to remove the following screws securing the left speaker to the upper case:
  20. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 20, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 20, imagem 2 %32
    • Lift and remove the left speaker out of the upper case.
  21. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, SSD Assembly: passo 21, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, SSD Assembly: passo 21, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, SSD Assembly: passo 21, imagem 3 %32
    • Use your thumb or finger to bend the plastic spring bar on the SSD tray, freeing the two clips at the front side of the device.
    • While holding the spring bar depressed, tilt the SSD assembly up out of its cavity.
  22. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 22, imagem 1 %32
    • Remove the SSD assembly from the upper case.
  23. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Battery: passo 23, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Battery: passo 23, imagem 2 %32
    • Remove three 2.2 mm T5 Torx screws from each side of the battery (six screws total).
  24. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 24, imagem 1 %32
    • The liquid adhesive remover provided in your kit can affect the antireflective coating on your MacBook Pro's display.
    • To protect your display, place a sheet of aluminum foil between the display and keyboard and leave it there while you work.
  25. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 25, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 25, imagem 2 %32
    • Now that your MacBook Pro is fully prepped, it's time to prep yourself.
    • iFixit adhesive remover contains acetone, a mild skin and eye irritant.
    • Wear eye protection when handling and applying the adhesive remover. (Eye protection is included in your kit.)
    • Do not wear contact lenses without eye protection.
    • Protective gloves are also included in your kit. If you are concerned about skin irritation, put your gloves on now.
  26. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 26, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 26, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 26, imagem 3 %32
    • Pull off the black rubber stopper from your bottle of adhesive remover.
    • Twist to loosen or remove the bottle cap before you cut the applicator tip.
    • This unseals the bottle and allows the pressure to equalize before you cut the applicator tip. If you skip this step, the adhesive remover may spray out unexpectedly when the tip is cut.
    • Use scissors to cut off the sealed tip of the applicator.
    • Cutting close to the narrow tip will give you better control so you can apply the adhesive remover in small amounts.
    • Twist and close the bottle cap securely before you proceed further.
  27. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 27, imagem 1 %32
    • Apply a few drops of adhesive remover evenly under the edge of the leftmost battery cell.
    • You don't need to use very much. The small bottle contains more than twice the amount of solvent needed to remove all the battery cells.
    • Wait 2-3 minutes for the liquid adhesive remover to penetrate underneath the battery cell before you proceed to the next step.
  28. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 28, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 28, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 28, imagem 3 %32
    Plastic Cards
    $2.99
    • Insert the flat edge of a spudger or plastic card underneath the leftmost battery cell.
    • Run your tool along the bottom perimeter of the battery cell and lift to begin separating the adhesive.
  29. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 29, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 29, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 29, imagem 3 %32
    • Insert the spudger along the left-hand side of the leftmost battery cell.
    • Run the spudger up along the left side of the leftmost battery cell.
    • Slightly pry the leftmost battery cell to release it from the adhesive.
  30. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 30, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 30, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 30, imagem 3 %32
    • Repeat the above steps to separate the adjacent battery cell from its adhesive:
    • Apply a few drops of liquid adhesive remover under the battery cell.
    • Wait 2-3 minutes for the adhesive remover to penetrate and soften the adhesive.
    • Carefully wedge a spudger or plastic card inwards, being careful to not damage the battery, and separate the battery cell from the adhesive securing it to your MacBook Pro.
  31. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 31, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 31, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 31, imagem 3 %32
    • Insert the flat end of a spudger underneath the larger leftmost battery cell.
    • Carefully wedge the spudger inwards, being careful to not damage the battery cells.
    • Pry the larger leftmost battery cell up off the upper case.
  32. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 32, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 32, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 32, imagem 3 %32
    • Grasp the battery cells and gently move (but do not remove) them from their recess in the upper case.
    • Leave the battery cells resting on top of the upper case as shown in the third picture.
  33. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 33, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 33, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 33, imagem 3 %32
    • Switch sides and repeat the above procedure for the two battery cells on the right-hand side of the MacBook Pro.
    • Remember to add a small amount of liquid adhesive remover under each battery cell, and wait 2-3 minutes for it to penetrate before prying up the cell.
    • Be careful not to puncture or otherwise damage the battery cells.
  34. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 34, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 34, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 34, imagem 3 %32
    • Lift the battery as a whole up out of the upper case, and remove the battery.
    • Before installing a new battery, remove all the old adhesive from the MacBook Pro's case.
    • With a little luck, you can slowly pull out each strip of adhesive with your fingers.
    • Otherwise, soak each section of adhesive with a bit of adhesive remover for 2-3 minutes, and then scrape it out with an opening pick or one of the other tools in your kit. This can take quite a bit of work, so be patient.
    • Mop up any remaining adhesive remover and give your MacBook Pro a few minutes to air dry.
    • The replacement battery included in your iFixit kit comes with adhesive pre-installed. Test the battery's fit and alignment carefully before peeling off the film covering the adhesive, and then press each cell firmly into place. If any additional films/liners are present that weren't on your original battery, remove them now.
    • Calibrate your newly installed battery: charge it to 100%, and keep charging it for at least 2 more hours. Unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook Pro's SMC.
  35. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Trackpad: passo 35, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement, Trackpad: passo 35, imagem 2 %32
    • Use the flat end of a spudger to flip up the retaining flap on the trackpad ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
  36. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 36, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 36, imagem 2 %32
    • Grasp the plastic pull tab and pull the trackpad ribbon cable out of its socket.
  37. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 37, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 37, imagem 2 %32
    • Wedge the spudger between the trackpad ribbon cable and the upper case.
    • Run the spudger along the bottom to release the trackpad ribbon cable from the adhesive securing it to the upper case.
  38. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 38, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 38, imagem 2 %32
    • Insert the tip of a spudger in between the trackpad ribbon cable and the upper case inside the SSD assembly cavity to remove the last of the adhesive.
  39. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 39, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 39, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 39, imagem 3 %32
    • Using the tip of the spudger carefully thread the trackpad ribbon cable out of the notch near the top of the SSD assembly cavity.
  40. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 40, imagem 1 %32
    • Remove the following screws securing the trackpad brackets to the trackpad and upper case:
    • Four 1.9 mm Phillips #000 screws
    • Four 1.4 mm Phillips #000 screws
  41. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 41, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 41, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 41, imagem 3 %32
    • Use tweezers to remove the two trackpad mounting brackets from the upper case.
  42. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 42, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 42, imagem 2 %32
    • To avoid scratching the display, open the computer about 90º and set it on end.
    • Guide the trackpad ribbon cable through the slot cut in the upper case. This will push the trackpad up out of its recess in the top of the upper case. Guide the trackpad out with your other hand, so it doesn't fall.
  43. MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 43, imagem 1 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 43, imagem 2 %32 MacBook Pro 13" Retina Display Late 2012 Trackpad Replacement: passo 43, imagem 3 %32
    • Gently pull the trackpad from the upper case, being careful not to snag the ribbon cable.
Conclusão
30 outras pessoas executaram este guia.
Sam Goldheart
Membro desde: 10/18/12
477.107 Reputação
Autoria de 538 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 25.518 guias
8Comentários do guia
No need at all to do all of this. Unless your ribbon cable is dead. Otherwise just pull up the SSD and that's it. Took 1mn30 to do..
Philippe - Responder Compartilhar
Figured that out- remove the top battery! Sorry - didn't read through all the directions carefully!
Ark - Responder Compartilhar
This can be done without removing the battery. The touchpad ribbon cable can be disconnected on the logic board, then snaked (gently!!) back out its channel with the battery in place.
It won't thread back through when replacing the touchpad though - it's not stiff enough. Instead, cut a strip of material from a manila folder and thread that through the channel under the battery. Then use masking tape to attach the touchpad cable to the manila strip and pull the strip out towards the logic board. The touchpad ribbon threads through the channel and the masking tape can be removed once it's in place.
Only the battery connector, SSD cable, and SSD carrier need removed.
R.G. Keen - Responder Compartilhar
I agree with the last comment. But I would prefer loosening the center battery and lifting it up to guide the trackpad cable easily. This also makes it easier to reinsert it into the connector during reassembly.
Robert - Responder Compartilhar
Steps 24-34 are UNNECESSARY for this repair! Removing the adhesive portion of the battery is not required to remove the trackpad. Just lift up the top part of the battery that is screwed in and unplug the trackpad cable.
bizwfshane - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 101
Ao todo: 29,416
