Introdução
Have your MacBook Pro feet seen better days? Use this guide to give your early 2013 MacBook Pro a fresh set of feet.
Remove the following ten screws securing the lower case to the upper case:
Two 2.3 mm P5 Pentalobe screws
Eight 3.0 mm P5 Pentalobe screws
Peel away any stickers from the backside of the rear case covering the feet you have chosen to replace.
Press the new foot into place firmly with your finger, then apply pressure by pinching the foot from either side of the case with your finger and your thumb.
Maintain pressure for 30 seconds to set the pressure-sensitive adhesive.
Repeat the last seven steps for any remaining broken or worn feet.
5 outras pessoas concluíram este guia.
Um comentário
Great kit for replacing the feet on a MacBook. Had a foot fall off my 6 year old MacBook Pro and this kit fit exactly!
