Ir para o conteúdo principal
MacBook Pro 13" Function Keys 2017 Trackpad Replacement
O que você precisa
  1. MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Disable Auto Boot: passo 1, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Disable Auto Boot: passo 1, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Disable Auto Boot: passo 1, imagem 3 %32
    • Before starting this procedure, you must disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide or follow the abbreviated instructions below to disable Auto Boot. This command may not work on all Macs.
    • Power on your Mac and launch Terminal.
    • Copy and paste the following command (or type it exactly) into Terminal:
    • sudo nvram AutoBoot=%00
    • Press [return]. If prompted, enter your administrator password and press [return] again. Note: Your return key may also be labeled ⏎ or "enter."
    • You can now safely power down your Mac and open the bottom case, without it accidentally powering on.
    • When your repair is complete and your Mac is successfully reassembled, re-enable Auto Boot with the following command:
    • sudo nvram AutoBoot=%03
  2. MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Lower Case: passo 2, imagem 1 %32
    Ferramenta utilizada neste passo:
    Magnetic Project Mat
    $19.95
    • Before proceeding, unplug and power down your MacBook. Close the display and lay it on a soft surface, top-side down.
    • Use a P5 Pentalobe driver to remove the six screws securing the lower case:
    • Two 6.2 mm screws
    • Two 5.3 mm screws
    • Two 3.4 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your device.
  3. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 3, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 3, imagem 2 %32
    • Apply a suction handle to the lower case near the front-center area of the MacBook Pro.
    • Lift the suction handle to create a slight separation between the lower case and the chassis.
  4. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 4, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 4, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 4, imagem 3 %32
    • Insert one corner of an opening pick into the space between the lower case and the chassis.
    • Slide the opening pick around the nearest corner and halfway up the side of the case.
    • This releases the first of the hidden clips securing the lower case to the chassis. You should feel and hear the clip pop free.
  5. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 5, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 5, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 5, imagem 3 %32
    • Repeat the previous step on the opposite side, sliding your opening pick under the lower case and up the side to pop the second clip free.
  6. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 6, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 6, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 6, imagem 3 %32
    • Insert your opening pick once again under the front edge of the lower case, near one of the two centermost screw holes.
    • Give the pick a firm twist to pop free the third clip securing the lower case to the chassis.
    • Repeat this procedure near the other of the two centermost screw holes, popping the fourth clip free.
  7. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 7, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 7, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 7, imagem 3 %32
    • Pull the lower case firmly towards the front of the MacBook (away from the hinge area) to separate the last of the clips securing the lower case.
    • It may help to pull first at one corner, then the other.
    • This may require a lot of force.
  8. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 8, imagem 1 %32
    • Remove the lower case.
  9. MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Battery Connector: passo 9, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Battery Connector: passo 9, imagem 2 %32
    • Carefully peel up the large piece of tape covering the battery connector, on the edge of the logic board nearest the battery.
    • Remove the tape.
  10. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 10, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 10, imagem 2 %32
    • Gently peel back the small piece of tape covering the battery board data cable connector.
    • The tape is integrated into the ribbon cable and will not detach completely. Simply peel it back enough to access the connector.
  11. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 11, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 11, imagem 2 %32
    • Use the tip of a spudger to flip up the small black locking tab securing the cable in its connector.
  12. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 12, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 12, imagem 2 %32
    • Disconnect the battery board data cable by sliding it out from its socket.
    • Slide parallel to the logic board, in the direction of the cable.
  13. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 13, imagem 1 %32
    • Fold the battery board data cable back and out of the way.
    • If you're replacing your battery, you may need to completely remove and transfer this cable to your new battery. Disconnect both ends and carefully remove the cable. During installation, be careful not to install it upside-down or backwards—note the orientation in the photos.
  14. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 14, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 14, imagem 2 %32
    • Use a T5 Torx driver to remove the 3.7 mm pancake screw securing the battery power connector.
  15. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 15, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 15, imagem 2 %32
    • Use a spudger to gently lift the battery power connector, disconnecting the battery.
    • Lift the connector high enough so that it stays separated from its socket. If it accidentally makes contact during the course of your repair, it could damage your MacBook Pro.
  16. MacBook Pro 13" Function Keys 2017 Trackpad Replacement, Trackpad: passo 16, imagem 1 %32
    • Use a T5 Torx driver to remove the two 2.1 mm screws securing the trackpad cable connector bracket.
  17. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 17, imagem 1 %32
    • Remove the trackpad cable connector bracket.
  18. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 18, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 18, imagem 2 %32
    • Use a spudger to disconnect the trackpad ribbon cable by gently prying its connector straight up from the logic board.
  19. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 19, imagem 1 %32
    • Prepare an iOpener and lay it on top of the trackpad ribbon cable for about a minute, in order to soften the adhesive securing the trackpad ribbon cable to the top of the battery.
    • If you don't have an iOpener, use a hair dryer to warm up the cable instead. The cable should be warm, but not too hot to touch. Be careful not to overheat the battery.
  20. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 20, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 20, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 20, imagem 3 %32
    • Carefully peel the trackpad ribbon cable up off the battery, and push it out of the way.
    • Do not fold or tear the cable.
  21. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 21, imagem 1 %32
    • Use a T5 Torx driver to remove the ten screws securing the trackpad assembly:
    • Two 4.3 mm screws
    • Eight 5.8 mm screws
  22. MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 22, imagem 1 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 22, imagem 2 %32 MacBook Pro 13" Function Keys 2017 Trackpad Replacement: passo 22, imagem 3 %32
    • Remove the trackpad assembly.
    • You'll need to swing the display open slightly to remove the trackpad.
    • Take care to feed the trackpad ribbon cable through the MacBook Pro's frame without snagging.
    • Be sure not to lose the six small washers (two circular and four rectangular) resting on the underside of the trackpad.
    • Make sure your new trackpad has a ribbon cable installed before reassembly. If necessary, transfer the old cable, or install the one your new trackpad came with.
Conclusão
11 outras pessoas executaram este guia.
Tarun Thiruma
Membro desde: 11/20/19
39.423 Reputação
Autoria de 134 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 6
Últimos 7 dias: 52
Últimos 30 dias: 192
Ao todo: 17,484
