Ir para o conteúdo principal
MacBook Core Duo Left I/O Frame Replacement
O que você precisa
  1. MacBook Core Duo Left I/O Frame Replacement, Battery: passo 1, imagem 1 %32
    • Use a coin or spudger to rotate the battery-locking screw 90 degrees clockwise.
  2. MacBook Core Duo Left I/O Frame Replacement: passo 2, imagem 1 %32
    • Lift the battery out of the computer.
  3. MacBook Core Duo Left I/O Frame Replacement, Memory Cover: passo 3, imagem 1 %32
    • Remove the three evenly-spaced Phillips screws from along the rear wall of the battery compartment.
    • The screws are captive to the metal memory cover.
    • When replacing the memory cover, use a spudger to re-insert the foam cushioning behind the rear wall for propper battery spacing.
  4. MacBook Core Duo Left I/O Frame Replacement: passo 4, imagem 1 %32
    • Lift up on L-shaped memory cover, slide it to the right, and lift it out of the computer.
  5. MacBook Core Duo Left I/O Frame Replacement, Upper Case: passo 5, imagem 1 %32
    • Remove the following 3 screws:
    • One 11 mm Phillips #00 in the middle of the case.
    • Two 14.5 mm Phillips #00.
    • If the screws stick in the case, you can use a magnetized screwdriver to draw them out.
    • The shorter of the three screws goes in the middle.
  6. MacBook Core Duo Left I/O Frame Replacement: passo 6, imagem 1 %32
    • Remove the following 3 screws from the rear wall of the battery compartment:
    • Two 3 mm Phillips #00. (A1181 has three 3 mm screws and one 4 mm.)
    • One 4 mm Phillips #00 on the right side.
    • When reinstalling these screws, press gently on the lower case to line up the screw holes.
    • These screws easily strip, so be careful while taking these particular screws out.
  7. MacBook Core Duo Left I/O Frame Replacement: passo 7, imagem 1 %32
    • Remove the two 6 mm Phillips #00 screws from either side of the right wall of the battery compartment (not the ones closest to the battery connector).
  8. MacBook Core Duo Left I/O Frame Replacement: passo 8, imagem 1 %32
    • Remove the four 3 mm indicated Phillips #00 screws from the front wall of the battery compartment. When working from the left, remove the 2nd, 4th, 7th and 9th screw.
  9. MacBook Core Duo Left I/O Frame Replacement: passo 9, imagem 1 %32
    • Remove the following 4 screws from the back of the computer:
    • Two 7 mm shouldered Phillips on the far sides.
    • Two 10.5 mm Phillips toward the center.
    • Do not over-tighten these; you can cause the case to distort.
  10. MacBook Core Duo Left I/O Frame Replacement: passo 10, imagem 1 %32
    • Remove the two 5.2 mm shouldered Phillips #00 screws from the optical side of the computer.
    • It is not necessary to remove the similar screws on the other side of the computer.
  11. MacBook Core Duo Left I/O Frame Replacement: passo 11, imagem 1 %32
    • Starting near the display and working around to the front of the computer, pry up on the upper case. It is held with clips on the right above the optical drive. These will release with some firm lifting pressure.
    • Be careful when prying up the upper case. It's very easy to slice open a fingertip and thus provide the blood sacrifice the Mac gods sometimes require of those who insist on doing their own repairs.
    • There's a trackpad and keyboard ribbon connecting the upper case to the logic board, so don't pull the upper case off entirely just yet.
    • If you have trouble getting the clips to release, be careful that you are not prying the plastic top of the upper case away from its metal frame.
  12. MacBook Core Duo Left I/O Frame Replacement: passo 12, imagem 1 %32
    • While holding up the upper case (from the bottom or the top), use a spudger to pry up the orange trackpad and keyboard cable from its connector.
    • Take care to pry between the black socket and the white connector. You might have to pry on both sides for it to release properly.
    • Do not pry from the bottom or the top, but from the sides.
    • If you happen to break your upper case cable when removing the upper case, we stock the cable individually and we have a guide that makes replacing it easy.
  13. MacBook Core Duo Left I/O Frame Replacement, Left I/O Frame: passo 13, imagem 1 %32
    • Disconnect the MagSafe board cable from the logic board.
  14. MacBook Core Duo Left I/O Frame Replacement: passo 14, imagem 1 %32
    • Remove the single Phillips screw securing the left speaker to the lower case.
    • Lift the left speaker out of its housing and set it to the side.
  15. MacBook Core Duo Left I/O Frame Replacement: passo 15, imagem 1 %32
    • Two 7.5 mm Phillips from either end of the left I/O frame.
    • One 9 mm Phillips from the middle of the left I/O frame.
    • Remove the small black plastic spacer at the bottom of the left I/O frame.
  16. MacBook Core Duo Left I/O Frame Replacement: passo 16, imagem 1 %32
    • Lift the left I/O frame up and out of the computer. Pay attention to the thin metal EMI fingers, as they may catch as you remove the left I/O frame.
Conclusão
3 outras pessoas executaram este guia.
iRobot
Membro desde: 09/24/09
1 Reputação
Autoria de 635 guias
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 1
Últimos 30 dias: 13
Ao todo: 14,534
