Ir para o conteúdo principal
MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement
O que você precisa
  1. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Lower Case: passo 1, imagem 1 %32
    • Unplug your MacBook Air and power it off before you proceed.
    • Remove ten Phillips screws securing the lower case to the MacBook Air:
    • Six 2.8 mm screws
    • Two 3.8 mm screws
    • Two 5.4 mm screws
    Pergunte ao FixBot
    Comentar
  2. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 2, imagem 1 %32 MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 2, imagem 2 %32
    • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
    Pergunte ao FixBot
    Comentar
  3. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Battery: passo 3, imagem 1 %32
    • Disconnect the battery connector by pulling it straight out of its socket.
    Pergunte ao FixBot
    Comentar
  4. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 4, imagem 1 %32
    • Remove the following nine screws securing the battery to the Air:
    • Four 2.9 mm Phillips.
    • Four 3.8 mm Phillips.
    • One 7.2 mm Phillips.
    Pergunte ao FixBot
    Comentar
  5. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 5, imagem 1 %32
    • Lift the battery out of the Air.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
    Pergunte ao FixBot
    Comentar
  6. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Logic Board Bracket: passo 6, imagem 1 %32
    • Remove the two small Phillips screws securing the logic board bracket to the upper case.
    Pergunte ao FixBot
    Comentar
  7. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 7, imagem 1 %32
    • Lift the logic board bracket out of the upper case.
    Pergunte ao FixBot
    Comentar
  8. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement, Trackpad Control Cable: passo 8, imagem 1 %32
    • Use a spudger to pry trackpad control cable connector up off the logic board.
    Pergunte ao FixBot
    Comentar
  9. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 9, imagem 1 %32
    • Use the pointed end of a spudger to flip up the retaining flap on the trackpad control cable socket.
    Pergunte ao FixBot
    Comentar
  10. MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 10, imagem 1 %32 MacBook Air Models A1237 and A1304 Trackpad Control Cable Replacement: passo 10, imagem 2 %32
    • Peel the trackpad control cable off the adhesive securing it to the upper case.
    • Pull the trackpad control cable out of its socket.
    Pergunte ao FixBot
    Comentar
Conclusão
5 outras pessoas executaram este guia.
1Comentário do guia
Hi, I was wondering if it's possible to remove the button pad on this model Air, and just install a regular trackpad like the ones in the Macbook Pro Unidbody's and up? Can someone let mek now if that is possible or do you need that click strip in order for it to function properly?
Jabran - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 14
Últimos 30 dias: 82
Ao todo: 21,630
