Ir para o conteúdo principal
MacBook Air Models A1237 and A1304 Audio Cable Replacement
O que você precisa
    1. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Lower Case: passo 1, imagem 1 %32
      • Unplug your MacBook Air and power it off before you proceed.
      • Remove ten Phillips screws securing the lower case to the MacBook Air:
      • Six 2.8 mm screws
      • Two 3.8 mm screws
      • Two 5.4 mm screws
      Pergunte ao FixBot
      Comentar
    2. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 2, imagem 1 %32 MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 2, imagem 2 %32
      • Slightly lift the lower case near the vents and push it toward the rear of the computer to free the mounting tabs.
      Pergunte ao FixBot
      Comentar
    1. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Battery: passo 3, imagem 1 %32
      • Disconnect the battery connector by pulling it straight out of its socket.
      Pergunte ao FixBot
      Comentar
    2. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 4, imagem 1 %32
      • Remove the following nine screws securing the battery to the Air:
      • Four 2.9 mm Phillips.
      • Four 3.8 mm Phillips.
      • One 7.2 mm Phillips.
      Pergunte ao FixBot
      Comentar
    3. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 5, imagem 1 %32
      • Lift the battery out of the Air.
      • If you're installing a new battery, you should calibrate it after installation:
      • Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
      • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
      Pergunte ao FixBot
      Comentar
    1. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Speaker: passo 6, imagem 1 %32
      • Remove the following two screws securing the speaker assembly to the upper case.
      • One 3 mm Phillips.
      • One 5.8 mm Phillips.
      Pergunte ao FixBot
      Comentar
    2. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 7, imagem 1 %32 MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 7, imagem 2 %32
      • Use a spudger to lift the audio-out connector board off the adhesive that secures it to the hard drive bracket.
      • Disconnect the audio out connector from its socket.
      Pergunte ao FixBot
      Comentar
    3. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 8, imagem 1 %32 MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 8, imagem 2 %32
      • Rotate the speaker assembly toward the center of the Air.
      • Use a spudger to pry the speaker cable connector up off the audio board.
      Pergunte ao FixBot
      Comentar
    1. MacBook Air Models A1237 and A1304 Audio Cable Replacement, Audio Cable: passo 9, imagem 1 %32 MacBook Air Models A1237 and A1304 Audio Cable Replacement, Audio Cable: passo 9, imagem 2 %32
      • Disconnect the port hatch ribbon cable from the logic board by pulling it straight up by its black pull tab.
      • If necessary, pull the audio out ribbon cable off the adhesive securing it to the upper case.
      Pergunte ao FixBot
      Comentar
    2. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 10, imagem 1 %32
      • Use the pointed end of a spudger to de-route the microphone cable from the hard drive bracket.
      Pergunte ao FixBot
      Comentar
    3. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 11, imagem 1 %32
      • Remove the following screws securing the hard drive to the upper case:
      • Two 3.9 mm Phillips screws.
      • One 4.7 mm Phillips screw.
      • This may be a Torx T6 screw.
      Pergunte ao FixBot
      Comentar
    4. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 12, imagem 1 %32
      • Use the tip of a spudger to remove the cosmetic screw cover to reveal the last remaining screw securing the hard drive.
      Pergunte ao FixBot
      Comentar
    5. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 13, imagem 1 %32
      • Remove the 4.7 mm Phillips screw securing the hard drive to the upper case.
      Pergunte ao FixBot
      Comentar
    6. MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 14, imagem 1 %32 MacBook Air Models A1237 and A1304 Audio Cable Replacement: passo 14, imagem 2 %32
      • Lift the hard drive slightly and use a spudger to pry the audio cable connector up off the logic board.
      • Peel the audio cable off the adhesive securing it to the upper case.
      Pergunte ao FixBot
      Comentar
Conclusão
94 outras pessoas executaram este guia.
7Comentários do guia
Great! it works!
Jorge - Responder Compartilhar
It's perfect guide. I had a same situaton with my Air and cable that I ordered from here works perfect.
Thanks
William Sawyer - Responder Compartilhar
I had no audio, with the sound icon in menu bar absent and volume panel grayed out. This repair worked! Be sure to label each screw type from each step of the guide (some screws that were supposed to be same mm from two different steps were not). Be careful not to strip screws when removing them, and not to cross-thread when reinserting. Thanks for the guide.
angbra - Responder Compartilhar
It works , easy to follow guide and super fast shipping of the cable (just 6days), thanks guys ! BRGDS from Spain
hectorramirezrodriguez - Responder Compartilhar
I have sound!!! Cable that i ordered here works perfekt for me too. Thank you very much.
michal - Responder Compartilhar
Comentar
Visualizações:
Últimas 24 horas: 8
Últimos 7 dias: 29
Últimos 30 dias: 84
Ao todo: 57,525
