Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Replace the black plastic bracket holding your AirPort/Bluetooth board to the upper case.
O que você precisa
Remove ten Phillips screws securing the lower case to the MacBook Air:
Six 2.8 mm screws
Two 3.8 mm screws
Two 5.4 mm screws
Lift the battery out of the Air.
Charge it to 100%, and then keep charging it for at least 2 more hours. Then, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Remove the two Phillips screws securing the AirPort/Bluetooth bracket to the upper case.
Uma outra pessoa concluiu este guia.
