Ir para o conteúdo principal
MacBook Air 2022 (M2) Screen Replacement
O que você precisa
  1. MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: passo 1, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: passo 1, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Prepare your Macbook Air for disassembly: passo 1, imagem 3 %32
    • Before you begin, discharge your battery below 25%, as a charged lithium-ion battery can be dangerous if accidentally punctured.
    • Power off your MacBook Air and unplug all cables.
    • Close the display and flip the laptop upside down. Keep the lid closed until you've physically disconnected the battery.
  2. MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: passo 2, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Unfasten the lower case: passo 2, imagem 2 %32
    Ferramenta utilizada neste passo:
    FixMat
    $36.95
    • Use a P5 Pentalobe driver to remove the four 6.4 mm screws securing the lower case:
    • Two screws with a short threaded portion near the hinges
    • Two screws with a long threaded portion near the front of the MacBook
  3. MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: passo 3, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: passo 3, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Insert an opening pick: passo 3, imagem 3 %32
    • Apply a suction handle to the center of the lower case's front edge.
    • Pull up on the suction handle with strong, steady force to create a small gap between the lower case and the frame.
    • Insert an opening pick into the gap.
  4. MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: passo 4, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: passo 4, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Release the snapping clips: passo 4, imagem 3 %32
    • During the next two steps you'll feel and hear four snapping clips release. If a clip doesn't release, insert your opening pick farther and try again.
    • Slide the pick to the bottom right corner to release the first clip.
    • Slide the pick around the corner and up the right edge to release the next clip.
  5. MacBook Air 2022 (M2) Screen Replacement: passo 5, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 5, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 5, imagem 3 %32
    • Insert the opening pick in the original gap created with the suction handle.
    • Slide the opening pick to the bottom left corner and up the left edge to release the two remaining snapping clips.
  6. MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: passo 6, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: passo 6, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Release the sliding tabs: passo 6, imagem 3 %32
    • Four sliding tabs along the back edge of the MacBook firmly secure the lower case. Separating these tabs requires a lot of force—consider using gloves to protect your hands from the sharp edges of the lower case.
    • Keep the lower case flat and firmly pull it straight away from the back edge, one corner at a time, to disengage the sliding tabs.
    • Don't pull up until the cover is completely separated.
  7. MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: passo 7, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: passo 7, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the lower case: passo 7, imagem 3 %32
    • Remove the lower case.
    • During reassembly:
    • Set the lower case in place and align the sliding tabs with the screw heads they slide over. Press down and slide the lower case toward the back edge to engage the tabs—it'll stop sliding as the tabs engage.
    • When one side is engaged, it may push the other out of alignment. Check both sides as you push, there should be no gap along the back edge.
    • Once the lower case is flush with the frame, press down firmly along the perimeter to engage the four snapping clips.
    • You'll hear and feel a distinct click as each clip snaps into place.
  8. MacBook Air 2022 (M2) Screen Replacement, Remove the battery connector cover: passo 8, imagem 1 %32
    • Use a T3 Torx driver to remove the two 1.5 mm screws securing the battery connector cover.
  9. MacBook Air 2022 (M2) Screen Replacement: passo 9, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 9, imagem 2 %32
    • Remove the battery connector cover.
  10. MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: passo 10, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Disconnect the battery: passo 10, imagem 2 %32
    • Use an opening pick to pry up and disconnect the battery press connector.
    • To reconnect a press connector, align it over the socket and gently press down on one side until it clicks into place, then press down on the other side. It might take a few tries to align the connector.
  11. MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: passo 11, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the display cable cover foam: passo 11, imagem 2 %32
    • Peel up and remove the foam pad from the lower display cable cover to reveal a hidden screw.
  12. MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: passo 12, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the cable covers: passo 12, imagem 2 %32
    • Use a T3 Torx driver to remove the nine 1.5 mm screws securing the four metal covers.
  13. MacBook Air 2022 (M2) Screen Replacement: passo 13, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 13, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 13, imagem 3 %32
    • Remove the four metal covers:
    • Two speaker cable covers
    • One display cable cover
    • One antenna cable cover
  14. MacBook Air 2022 (M2) Screen Replacement: passo 14, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 14, imagem 2 %32
    • Remove the four screws securing the upper display cable cover:
    • Two 2.5 mm P2 Pentalobe screws
    • Two 2.5 mm 3IP Torx plus screws
    • During reassembly, the Pentalobe screws must thread into the display cable securing bracket.
  15. MacBook Air 2022 (M2) Screen Replacement: passo 15, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 15, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 15, imagem 3 %32
    • Remove the upper display cable cover and plastic securing bracket.
    • During reassembly, make sure the top edge of the upper display cable cover is under the securing bracket.
  16. MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: passo 16, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: passo 16, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Disconnect the cables: passo 16, imagem 3 %32
    • Use the pointed end of a spudger to pry up and disconnect both display cable press connectors.
  17. MacBook Air 2022 (M2) Screen Replacement: passo 17, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 17, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 17, imagem 3 %32
    • Disconnect the left and right speaker press connectors.
  18. MacBook Air 2022 (M2) Screen Replacement: passo 18, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 18, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 18, imagem 3 %32
    • Use a pair of tweezers to grip the first antenna connector, as close to its base as possible.
    • Lift straight up to disconnect the cable.
    • The antenna connectors on the logic board are very fragile. When disconnecting the cables, pull straight up—don’t bend them to the side.
    • Repeat for the second antenna cable.
    • To reattach antenna connectors like these, align the connector over its socket and press down with the flat end of a spudger. The connector should snap into place. This can be tricky and may take a few tries.
  19. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: passo 19, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge covers: passo 19, imagem 2 %32
    • These screws strip easily. Apply constant, downward force to prevent stripping.
    • Use a 3IP Torx Plus driver to remove the two 2.6 mm screws securing the right and left hinge covers.
  20. MacBook Air 2022 (M2) Screen Replacement: passo 20, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 20, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 20, imagem 3 %32
    • Grip the left hinge cover with blunt nose tweezers.
    • Pull the cover towards the bottom of the laptop and upwards to free it from its recess.
    • Pull up and remove the hinge cover.
  21. MacBook Air 2022 (M2) Screen Replacement: passo 21, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 21, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 21, imagem 3 %32
    • Repeat the previous step to remove the right hinge cover.
  22. MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: passo 22, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the speakers: passo 22, imagem 2 %32
    • Remove the six screws securing the left and right speakers:
    • Four 5.6 mm 4IP Torx Plus screws (two on each speaker)
    • Two 3.5 mm T5 Torx screws (one on each speaker)
  23. MacBook Air 2022 (M2) Screen Replacement: passo 23, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 23, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement: passo 23, imagem 3 %32
    • Lift the speakers straight up and remove them.
  24. MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: passo 24, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Disconnect the lid-angle sensor: passo 24, imagem 2 %32
    • Use a T3 Torx screwdriver to remove the two 1.5 mm screws securing the lid-angle sensor connector cover.
  25. MacBook Air 2022 (M2) Screen Replacement: passo 25, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 25, imagem 2 %32
    • Remove the lid-angle sensor connector cover.
  26. MacBook Air 2022 (M2) Screen Replacement: passo 26, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 26, imagem 2 %32
    • Use the pointed end of a spudger to pry up and disconnect lid angle sensor press connector.
  27. MacBook Air 2022 (M2) Screen Replacement: passo 27, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement: passo 27, imagem 2 %32
    • Gently peel the lid angle sensor cable from the top of the headphone jack and move it out of the way.
  28. MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: passo 28, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: passo 28, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Check for a lid‑angle sensor: passo 28, imagem 3 %32
    • Check if your replacement screen has a lid‑angle sensor installed on the hinge. If it does, skip this step. Otherwise, follow this step to remove the sensor—you'll need to transfer it to your replacement screen.
    • Use the point of a spudger to lift the flap covering the lid‑angle sensor screw, located on the left hinge.
    • Use a 1IP Torx Plus driver to remove the screw securing the lid‑angle sensor.
    • Remove the lid‑angle sensor and set it aside for reassembly.
  29. MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: passo 29, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Loosen the hinge screws: passo 29, imagem 2 %32
    • Use an 8IP Torx Plus driver to loosen (not remove) the six hinge screws.
  30. MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: passo 30, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Open your MacBook and set it down: passo 30, imagem 2 %32
    • Fully open your MacBook and gently place it keyboard side down on a table so the screen hangs over the edge.
  31. MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: passo 31, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: passo 31, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the hinge screws: passo 31, imagem 3 %32
    • Support the screen with one hand and use your free hand to remove the six 4.3 mm 8IP Torx Plus screws securing the hinges.
    • Keep a firm grip on your laptop, as it can easily fall off the table.
  32. MacBook Air 2022 (M2) Screen Replacement, Remove the screen: passo 32, imagem 1 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: passo 32, imagem 2 %32 MacBook Air 2022 (M2) Screen Replacement, Remove the screen: passo 32, imagem 3 %32
    • Hold the screen with both hands and lift the hinges out of their recesses to remove the screen.
    • Make sure the screen hinges are fully open and guide them into their recesses in the frame.
    • Install and partially tighten the six hinge screws.
    • Close your laptop and make sure the screen is properly aligned. If it clicks or snaps, readjust the alignment.
    • Fully tighten the hinge screws.
Conclusão
Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before you install it.
Repair didn’t go as planned? Try some basic troubleshooting or check out our Answers community for help.
34 outras pessoas executaram este guia.
Spencer Day
Membro desde: 09/14/22
155.036 Reputação
Autoria de 1.033 guias
Equipe
iFixit Membro de iFixit
Staff
123 Membros
Autoria de 23.765 guias
32Comentários do guia
Does the screen display normally after replacing it with the aftermarket screen? As far as I know, after 2021, MacBooks have problems with screen output when they are replaced with aftermarket screens.
https://www.ifixit.com/News/73288/m2-mac...
wellbinnn - Responder
Hi! We tested swapping screens between two M2 MacBook Airs and didn't find any issues with the screen. The problem is with the MacBook Pros.
Spencer Day -
I checked your comment. Thanks for checking!
Is this doable without scratching or chipping the body if done using the ifixit tool kit?
John Mashconzone - Responder
Hello! It's definitely doable! If you're worried, I would take extra care when standing the laptop up to make sure you set it on a surface that won't scratch the body. Also, be careful when guiding the hinges out of the frame to avoid brushing against the frame.
Spencer Day -
Comentar
Visualizações:
Últimas 24 horas: 194
Últimos 7 dias: 1,054
Últimos 30 dias: 4,517
Ao todo: 102,536
