Ir para o conteúdo principal
MacBook Air 13" Late 2020 Touch ID Sensor Replacement
O que você precisa
  1. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the screws securing the lower case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.3 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: passo 2, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: passo 2, imagem 2 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the lower case: passo 2, imagem 3 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop off the lower case.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: passo 3, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: passo 3, imagem 2 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the battery: passo 3, imagem 3 %32
    • Use the flat end of a spudger to pry up and unlatch the metal locking arm on the battery connector.
    • Make sure the metal arm is completely free of the locking tab before lifting the battery connector. The metal locking arm should easily unlatch.
    • Lift straight up on the metal locking arm to pull the battery connector out of its socket on the logic board.
    • During reassembly, press the battery connector straight down into its socket, making sure it sits flush within the socket.
    • If necessary, push the rear, wire side of the connector into place first, then rock the front of the connector into place.
  4. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board connector cover: passo 4, imagem 1 %32
    • Use a T3 Torx driver to remove the three 1.4 mm screws securing the audio board connector cover.
    • If your T3 bit feels a bit too loose, you may need to use a T4.
  5. MacBook Air 13" Late 2020 Touch ID Sensor Replacement: passo 5, imagem 1 %32
    • Remove the audio board connector cover.
  6. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: passo 6, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: passo 6, imagem 2 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the speaker: passo 6, imagem 3 %32
    • Slide the pointed end of a spudger underneath the speaker cable and pry straight up to disconnect it.
  7. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: passo 7, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: passo 7, imagem 2 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the Touch ID cable: passo 7, imagem 3 %32
    • Use the flat end of a spudger to pry the Touch ID cable straight up to disconnect it from the audio board.
    • Continue to slide the spudger underneath the Touch ID cable to release it from the audio board.
    • The Touch ID cable is secured to the audio board with some light adhesive.
  8. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the audio board cable: passo 8, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Disconnect the audio board cable: passo 8, imagem 2 %32
    • Use the flat end of a spudger to pry the audio board connector straight up to disconnect it from the board.
    • To re-attach press connectors like this one, carefully align and press down on one side until it clicks into place, then repeat on the other side. Do not press down on the middle. If the connector is misaligned, the pins can bend, causing permanent damage.
  9. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board screws: passo 9, imagem 1 %32
    • Remove the three screws securing the audio board:
    • Two 4.8 mm T5 Torx screws
    • One 2.5 mm T3 Torx screw
  10. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: passo 10, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: passo 10, imagem 2 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the audio board: passo 10, imagem 3 %32
    • Use a spudger to pry the audio board out of the upper case until you can grip it with your fingers.
    • Remove the audio board.
  11. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor screws: passo 11, imagem 1 %32 MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor screws: passo 11, imagem 2 %32
    • Use a T3 Torx driver to remove the six 1.6 mm screws securing the Touch ID sensor and its bracket.
    • During reassembly, if you want your Touch ID button to be straight, don't tighten down the six screws until you adjust its position on the keyboard.
  12. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID bracket: passo 12, imagem 1 %32
    • Remove the Touch ID sensor bracket.
    • During reassembly, make sure the sensor bracket is oriented correctly.
  13. MacBook Air 13" Late 2020 Touch ID Sensor Replacement, Remove the Touch ID sensor: passo 13, imagem 1 %32
    • Turn the MacBook right-side up and open the display.
    • Remove the Touch ID sensor.
Conclusão
Once you've completed your repair, your laptop may not power back on until connected to power.
9 outras pessoas executaram este guia.
Carsten Frauenheim
Membro desde: 03/10/20
114.406 Reputação
Autoria de 338 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.243 guias
4 comentários
Servus! Angenommen, der Stecker hat sich beim Sturz nur gelöst und man steckt ihn wieder drauf. Kann man dann Touch ID wieder nutzen? Ode muss man immer das Logicboard tauschen, sobald der Stecker abgelöst wurde? Grüße
David Braun - Responder
Is it safe to remove the power button without going through the back? My touch sensor isn't working and I think something's blocking it. I simply want to remove the power key to clean... and put it right back in.
Kemi Burgen - Responder
No, the 4 screws holding the bottom of the button are on the inside, so you have to follow this guide to check your issue.
jeremyfitz -
Anyway to turn on my 2019 macbook pro with a broken touch id flex cable?
Nathan Morris - Responder
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 19
Últimos 7 dias: 153
Últimos 30 dias: 723
Duração total: 19,894
