Ir para o conteúdo principal
MacBook Air 13" Early 2020 Right Speaker Replacement
O que você precisa
  1. MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the screws securing the lower case: passo 1, imagem 1 %32
    Ferramenta utilizada nesse passo:
    Magnetic Project Mat
    $19.95
    Comprar
    • Before starting this procedure, you should disable your Mac's Auto Boot feature. Auto Boot powers on your Mac when you open the lid, and may be accidentally triggered during disassembly. Use this guide to disable Auto Boot.
    • If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
    • Completely power off and unplug your MacBook Air before you start. Close the display and flip the entire laptop upside-down.
    • Use a P5 driver to remove the following screws:
    • Two 7.9 mm screws
    • Two 7.1 mm screws
    • Six 2.6 mm screws
    • Throughout this repair, keep track of each screw and make sure it goes back exactly where it came from to avoid damaging your MacBook.
  2. MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the lower case: passo 2, imagem 1 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the lower case: passo 2, imagem 2 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the lower case: passo 2, imagem 3 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
    • Remove the lower case.
    • To reinstall the lower case:
    • Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
  3. MacBook Air 13" Early 2020 Right Speaker Replacement, Disconnect the battery: passo 3, imagem 1 %32
    • Peel back the tape covering the battery connector enough to reveal the connector underneath.
  4. MacBook Air 13" Early 2020 Right Speaker Replacement: passo 4, imagem 1 %32 MacBook Air 13" Early 2020 Right Speaker Replacement: passo 4, imagem 2 %32
    • Use a spudger to slide the battery connector parallel to the logic board and out of its socket on the logic board.
  5. MacBook Air 13" Early 2020 Right Speaker Replacement, Disconnect the right speaker connector: passo 5, imagem 1 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Disconnect the right speaker connector: passo 5, imagem 2 %32
    • The right speaker will be on your lefthand side when working on the MacBook, as it's laying upside down.
    • Slide the pointed end of a spudger underneath the right speaker cable and pry straight up to disconnect it from the audio board.
  6. MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker screw: passo 6, imagem 1 %32
    • Use a T3 Torx driver to remove the 4.2 mm screw securing the right speaker to the case.
  7. MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker adhesive: passo 7, imagem 1 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker adhesive: passo 7, imagem 2 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker adhesive: passo 7, imagem 3 %32
    • Use a pair of tweezers to lift up the black adhesive pull tab at the bottom of the right speaker, enough so you can grab it with your fingers.
    • Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
    • Keep the angle of the adhesive strip as parallel to the laptop as you can. Try to avoid dragging it across the inside of the case.
    • Pull the adhesive strip until it's freed from under the speaker.
    • If the adhesive strip breaks, use a heated iOpener, a heat gun, or a hair dryer to help remove the adhesive:
    • Apply heat to the speaker to soften the adhesive underneath.
    • Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
  8. MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker: passo 8, imagem 1 %32 MacBook Air 13" Early 2020 Right Speaker Replacement, Remove the right speaker: passo 8, imagem 2 %32
    Tesa 61395 Tape
    $5.99
    Comprar
    • Remove the right speaker.
    • During reassembly, to ensure the speaker performs as expected, install a strip of replacement adhesive on its underside before placing it back into the case.
Conclusão
Carsten Frauenheim
Membro desde: 03/10/20
113.865 Reputação
Autoria de 338 guias
Equipe
iFixit Membro de iFixit
Staff
Membros da 135
Autoria de 17.125 guias
0 comentários
Adicione um comentário
Exibir estatísticas:
Últimas 24 horas: 3
Últimos 7 dias: 30
Últimos 30 dias: 87
Duração total: 2,493
