Introdução
Use this guide to remove or replace the left speaker in an Early 2020 MacBook Air.
O que você precisa
If your MacBook is running Big Sur v11.1 or later, disabling Auto Boot may not work. You can proceed normally, but make sure to disconnect the battery as soon as you're inside.
Use a P5 driver to remove the following screws:
Two 7.9 mm screws
Two 7.1 mm screws
Six 2.6 mm screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case.
Set it in place and press firmly to engage the two hidden clips underneath. You should feel and hear them snap into place.
Peel back the tape covering the battery connector enough to reveal the connector underneath.
Slide the pointed end of a spudger underneath the left speaker cable and pry straight up to disconnect it from the logic board.
With the connector disconnected, slide the flat end of a spudger under the cable to separate the adhesive securing the cable to the logic board.
Use a T3 Torx driver to remove the 4.2 mm screw securing the left speaker to the case.
Use a pair of tweezers to peel back the black pull tab on the speaker's stretch-release adhesive until you can grip it with your fingers.
Grab the adhesive strip's pull tab and slowly pull the adhesive strip out from underneath the speaker.
Pull the adhesive strip until it's freed from under the speaker.
Apply heat to the speaker to soften the adhesive underneath.
Carefully slide a spudger or opening pick underneath the speaker to separate the adhesive.
Remove the left speaker.
