Introdução
Use this guide to upgrade or replace the solid-state drive in a MacBook Air 13” Early 2015. This MacBook Air uses a proprietary storage drive connector, and is therefore not compatible with common M.2 drives without the use of an adapter.
Before you perform this repair, if at all possible, back up your existing SSD. Then, either familiarize yourself with internet recovery or create a bootable external drive so you’ll be ready to install macOS onto your new drive and migrate your data to the new SSD.
Finally, we strongly recommend installing macOS 10.13 High Sierra (or a later macOS) before replacing the original SSD from your MacBook Air. Most new SSDs require updated storage drivers not found in versions of macOS prior to High Sierra.
O que você precisa
Vídeo de Apresentação
Ferramenta utilizada neste passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it parallel to the board toward the front edge of the Air.
Remove the single 2.9 mm T5 Torx screw securing the SSD to the logic board.
213 outras pessoas executaram este guia.
51Comentários do guia
yes) and prompt and appropriate model that was not inferior in speed built.
Thank!
Dave, I am sure these are M.2 SSD. I am not sure what apple uses but at least you have somewhere you can start for research
klacorum -
That’s indeed an M.2 SSD but you’ll need an adapter as the one that came with the Macbook uses a proprietary connector.
