Introdução
Use this guide to replace the display assembly.
Ferramentas
Peças
Use a P5 Pentalobe driver to remove ten screws securing the lower case, of the following lengths:
Two 9 mm screws
Eight 2.6 mm screws
Grab the clear plastic pull tab attached to the battery connector and pull it toward the front edge of the Air to disconnect the battery from the logic board.
Use the flat end of a spudger to pry the I/O board cable connector up out of its socket on the I/O board.
Use the tip of a spudger to carefully flip up the retaining flap on the fan cable ZIF socket.
Disconnect the I/O board by pulling its power cable away from its socket on the logic board.
Use the flat end of a spudger to pry each of the antenna connectors up from their sockets on the AirPort/Bluetooth card.
21 outras pessoas concluíram este guia.
Um comentário
Beware some of the connectors are tiny. I got it apart but broke the left speaker connection trying to get it off. Putting it back together I couldn’t get the microphone connector back together. I could live without those, but then I couldn’t connect the fan ribbon connector–I don’t know if I broke it taking it out but no go. Your mileage might vary but I killed my Mac.
