Este guia tem alterações mais recentes. Mudar para a última versão não verificada.
Introdução
Navigating through your computer using the TAB key is not fun. Replace a broken trackpad using this guide.
O que você precisa
Ferramenta utilizada nesse passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
Use the point of a spudger to lift the ZIF connector retaining flap on the trackpad data cable.
Gently slide the ribbon cable out of the ZIF connector.
Adjust, but do not remove the T5 Trackpad Sensitivity Screw to change the trackpad's depth sensitivity.
29 outras pessoas executaram este guia.
7 comentários
Bought a T5 screwdriver. Screws on my Macbook Air late 2011 won't turn. I thought one was unscrewing but as it turned out, I was just destroying the screw so it is now stuck forever and I'll never be able to open this thing. Great, I really do have an aluminium pile of trash now.
Thanks! Updated.
Please remove this guide. It has errors that cause me to strip one of my track pad screws. (Good otherwise and thanks for writing it.)
There is an almost identical guide MacBook Air 13" Mid 2011 Trackpad Replacement
that list the correct screw size #000 for the track pad and also shows the correct battery connector for my 2011 13" MacBook Air.
