Ir para o conteúdo principal
MacBook Air 11" Late 2010 Left Speaker Replacement
O que você precisa
  1. MacBook Air 11" Late 2010 Left Speaker Replacement, Lower Case: passo 1, imagem 1 %32
    Ferramenta utilizada neste passo:
    P5 Pentalobe Screwdriver Retina MacBook Pro and Air
    $5.99
    • Before proceeding, close your computer and lay it on a soft surface top-side down.
    • Remove the following ten screws:
    • Two 8 mm 5-point Pentalobe screws
    • Eight 2.5 mm 5-point Pentalobe screws
    • The special screwdriver needed to remove the eight 5-point Pentalobe screws can be found here.
  2. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 2, imagem 1 %32
    • Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
  3. MacBook Air 11" Late 2010 Left Speaker Replacement, Battery: passo 3, imagem 1 %32 MacBook Air 11" Late 2010 Left Speaker Replacement, Battery: passo 3, imagem 2 %32
    • Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
    • Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
  4. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 4, imagem 1 %32
    • Remove the following five screws securing the battery to the upper case:
    • Two 5.2 mm T5 Torx screws
    • One 6 mm T5 Torx screw
    • Two 2.6 mm T5 Torx screws
  5. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 5, imagem 1 %32
    • When handling the battery, avoid squeezing or touching the six exposed lithium polymer cells.
    • Lift the battery from its edge nearest the logic board and remove it from the upper case.
    • If you're installing a new battery, you should calibrate it after installation:
    • Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
    • If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
  6. MacBook Air 11" Late 2010 Left Speaker Replacement, Left Speaker: passo 6, imagem 1 %32
    • Use the flat end of a spudger to pry the I/O board cable connector upward out of its socket on the I/O board.
  7. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 7, imagem 1 %32 MacBook Air 11" Late 2010 Left Speaker Replacement: passo 7, imagem 2 %32 MacBook Air 11" Late 2010 Left Speaker Replacement: passo 7, imagem 3 %32
    • Use the tip of a spudger to flip up the retaining flap on the microphone ribbon cable ZIF socket.
    • Be sure you are prying up on the hinged retaining flap, not the socket itself.
    • Pull the microphone ribbon cable straight out of its socket.
  8. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 8, imagem 1 %32
    • Use the tip of a spudger to de-route the left speaker cable from the notch cut into the edge of the I/O board.
  9. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 9, imagem 1 %32
    • Use the flat end of a spudger to pry the left speaker connector up and out of its socket on the I/O board.
    • Pry upward from beneath the wires.
  10. MacBook Air 11" Late 2010 Left Speaker Replacement: passo 10, imagem 1 %32 MacBook Air 11" Late 2010 Left Speaker Replacement: passo 10, imagem 2 %32
    • Use the flat end of a spudger to pry the left speaker off the adhesive securing it to the upper case.
    • Only pry up on the speaker from the areas of bare aluminum on the upper case. Prying up from the keyboard area may damage the keyboard and the speaker itself.
    • Remove the left speaker from the upper case.
Conclusão
3 outras pessoas executaram este guia.
0Comentários do guia
Comentar
Visualizações:
Últimas 24 horas: 0
Últimos 7 dias: 0
Últimos 30 dias: 18
Ao todo: 5,368
