Esta versão pode conter edições incorretas. Mude para o último instantâneo verificado.
O que você precisa
Este passo não foi traduzido. Ajude a traduzi-lo
Ferramenta utilizada nesse passo:P5 Pentalobe Screwdriver Retina MacBook Pro and Air$5.99-
Remove the following ten screws:
Two 8 mm 5-point Pentalobe screws
Eight 2.5 mm 5-point Pentalobe screws
Wedge your fingers between the display and the lower case and pull upward to pop the lower case off the Air.
Remove the lower case and set it aside.
Use the flat end of a spudger to pry both short sides of the battery connector upward to disconnect it from its socket on the logic board.
Bend the battery cable slightly away from the logic board so the connector will not accidentally contact its socket.
Remove the following five screws securing the battery to the upper case:
Two 5.2 mm T5 Torx screws
One 6 mm T5 Torx screw
Two 2.6 mm T5 Torx screws
Lift the battery from its edge nearest the logic board and remove it from the upper case.
Charge it to 100%, and then keep charging it for at least 2 more hours. Next, unplug and use it normally to drain the battery. When you see the low battery warning, save your work, and keep your laptop on until it goes to sleep due to low battery. Wait at least 5 hours, then charge your laptop uninterrupted to 100%.
If you notice any unusual behavior or problems after installing your new battery, you may need to reset your MacBook's SMC.
115 outras pessoas executaram este guia.
21 comentários
Now my touchpad isn't working as well as before. Any ideas why?
Dead on Accurate. Was very easy. I would change the rating from moderate to easy. The hardest part is getting the correct screw drivers.
hello, is there any difference between A1370 (late 2010) battery part and a A1370 (2011) battery?
I'm also wondering the same thing. Did you find the answer to your question? Thank you.
swj.sean -
