Ir para o conteúdo principal
Mac mini Mid 2011 Logic Board Replacement
O que você precisa
  1. Mac mini Mid 2011 Logic Board Replacement, Bottom Cover: passo 1, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement, Bottom Cover: passo 1, imagem 2 %32
    • Place your thumbs in the depressions cut into the bottom cover.
    • Rotate the bottom cover counter-clockwise until the white dot painted on the bottom cover is aligned with the ring inscribed on the outer case.
    • You do not need to apply much downward pressure while turning.
  2. Mac mini Mid 2011 Logic Board Replacement: passo 2, imagem 1 %32
    • Tilt the mini enough to allow the bottom cover to fall away from the outer case.
    • Remove the bottom cover and set it aside.
  3. Mac mini Mid 2011 Logic Board Replacement, Fan: passo 3, imagem 1 %32
    • Remove the two 11.3 mm T6 Torx screws securing the fan to the logic board near the antenna plate.
  4. Mac mini Mid 2011 Logic Board Replacement: passo 4, imagem 1 %32
    • Lift the ear of the fan nearest the RAM up off the standoff secured to the outer case.
    • Removing the standoff screw is not necessary to remove the fan. You need only raise the fan enough to lift it off the standoff screw.
  5. Mac mini Mid 2011 Logic Board Replacement: passo 5, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 5, imagem 2 %32 Mac mini Mid 2011 Logic Board Replacement: passo 5, imagem 3 %32
    • Lift the fan out of the mini for enough clearance to access its connector.
    • Grab all the wires at once and gently pull straight up to disconnect the fan from the logic board.
    • Do not pry at the socket, or you may rip it from the logic board.
    • Remove the fan.
  6. Mac mini Mid 2011 Logic Board Replacement, Cowling: passo 6, imagem 1 %32
    • Remove the single 3.5 mm T6 Torx screw securing the cowling to the heat sink.
  7. Mac mini Mid 2011 Logic Board Replacement: passo 7, imagem 1 %32
    • Lift the cowling from the end nearest the antenna plate.
    • Rotate the cowling away from the outer case and remove it from the mini.
  8. Mac mini Mid 2011 Logic Board Replacement, Antenna Plate: passo 8, imagem 1 %32
    • Remove the following screws securing the antenna plate to the mini:
    • Two 6.6 mm T8 Torx screws
    • Two 5.0 mm T8 Torx or 2.0 mm Hex screws (either screwdriver will work)
    • When putting back together:
    • It can be difficult to get the hard drive seated correctly such that the antenna plate fits in place correctly. If the screw holes don't line up with those on the hard drive, make sure that the two pins that are in the back of the hard drive are properly seated in the holes at the back of the case, above the housing for the second hard drive.
    • The antenna attaches directly to the hard drive (red markers), therefore attaching the antenna can move the hard drive around and loosen the connection of the hard drive cable to the logic board.
  9. Mac mini Mid 2011 Logic Board Replacement: passo 9, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 9, imagem 2 %32
    • Slightly lift the antenna plate from the end closest to the RAM.
    • Carefully pull the antenna plate away from the circular rim of the outer case.
    • Do not remove the antenna plate yet. It is still attached to the AirPort/ Bluetooth board.
  10. Mac mini Mid 2011 Logic Board Replacement: passo 10, imagem 1 %32
    • Use the tip of a spudger to carefully pry the antenna connector up from its socket on the AirPort/Bluetooth board.
  11. Mac mini Mid 2011 Logic Board Replacement: passo 11, imagem 1 %32
    • Remove the antenna plate from the mini.
  12. Mac mini Mid 2011 Logic Board Replacement, Logic Board: passo 12, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement, Logic Board: passo 12, imagem 2 %32
    • Use the flat end of a spudger to pry the hard drive connector up from its socket on the logic board.
  13. Mac mini Mid 2011 Logic Board Replacement: passo 13, imagem 1 %32
    • Use the tip of a spudger to lift the IR sensor connector up and out of its socket on the logic board.
    • Make sure to pry up from beneath the wires and not underneath the socket.
  14. Mac mini Mid 2011 Logic Board Replacement: passo 14, imagem 1 %32
    • Remove the following three screws:
    • One 5.0 mm T8 Torx or 2.0 mm Hex screw (either screwdriver will work)
    • One 16.2 mm T6 Torx screw
    • One 26 mm T6 Torx standoff
  15. Mac mini Mid 2011 Logic Board Replacement: passo 15, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 15, imagem 2 %32 Mac mini Mid 2011 Logic Board Replacement: passo 15, imagem 3 %32
    Ferramenta utilizada neste passo:
    Mac mini Logic Board Removal Tool
    • To remove the logic board, the two cylindrical rods of the Mac mini Logic Board Removal Tool must be inserted into the holes highlighted in red. Inserting instruments into any logic board holes other than the ones highlighted in red may destroy the logic board.
    • Insert the Mac mini Logic Board Removal Tool into the two holes highlighted in red. Be sure it makes contact with the top side of outer case below the logic board before proceeding.
    • Carefully pull the tool toward the I/O board. The logic board and I/O board assembly should slightly slide out of the outer case.
    • Cease prying when the I/O board is visibly separated from the outer case.
    • Remove the Mac mini Logic Board Removal tool.
  16. Mac mini Mid 2011 Logic Board Replacement: passo 16, imagem 1 %32
    • Pull the I/O board/logic board assembly out of the outer case enough to access the power connector.
    • Use your fingers to disconnect the DC-In cable from the logic board.
    • Pull the power cable connector toward the front side of the mini.
  17. Mac mini Mid 2011 Logic Board Replacement: passo 17, imagem 1 %32
    • Carefully slide the logic board assembly out of the mini, minding any cables that may get caught.
  18. Mac mini Mid 2011 Logic Board Replacement, PRAM Battery: passo 18, imagem 1 %32
    • The PRAM battery is located on the top side of the logic board.
    • Use the tip of a spudger to carefully pry the PRAM battery up and out of its holder on the logic board.
  19. Mac mini Mid 2011 Logic Board Replacement: passo 19, imagem 1 %32
    • Remove the PRAM battery from the logic board.
    • The PRAM battery is a commonly available BR2032 coin-cell.
  20. Mac mini Mid 2011 Logic Board Replacement, Speaker: passo 20, imagem 1 %32
    • Remove the following two screws securing the speaker to the logic board assembly:
    • One 3.5 mm T6 Torx screw
    • One 3.7 mm T6 Torx screw
  21. Mac mini Mid 2011 Logic Board Replacement: passo 21, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 21, imagem 2 %32
    • Lift but do not remove the speaker assembly, as it still remains connected to the logic board via the speaker connector.
    • Carefully lift the speaker wires upward to lift the speaker connector up and out of its socket on the logic board.
    • Lift and remove the speaker away from the logic board.
  22. Mac mini Mid 2011 Logic Board Replacement, AirPort/Bluetooth Board: passo 22, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement, AirPort/Bluetooth Board: passo 22, imagem 2 %32
    • Use the flat end of a spudger to pry both antenna connectors up from their sockets on the AirPort/Bluetooth board.
  23. Mac mini Mid 2011 Logic Board Replacement: passo 23, imagem 1 %32
    • Use your spudger to help disconnect the AirPort/Bluetooth ribbon cable from its socket on the AirPort/Bluetooth board.
  24. Mac mini Mid 2011 Logic Board Replacement: passo 24, imagem 1 %32
    • Remove the two 2.6 mm T6 Torx screws securing the AirPort/Bluetooth board to the logic board.
  25. Mac mini Mid 2011 Logic Board Replacement: passo 25, imagem 1 %32
    • Remove the AirPort/Bluetooth board from the logic board.
  26. Mac mini Mid 2011 Logic Board Replacement, Logic Board: passo 26, imagem 1 %32
    • Use the flat end of a spudger to pry the AirPort/Bluetooth ribbon cable up off the logic board.
    • Remove the AirPort/Bluetooth ribbon cable.
  27. Mac mini Mid 2011 Logic Board Replacement: passo 27, imagem 1 %32 Mac mini Mid 2011 Logic Board Replacement: passo 27, imagem 2 %32 Mac mini Mid 2011 Logic Board Replacement: passo 27, imagem 3 %32
    • Release the tabs on each side of the RAM chip by simultaneously pushing each tab away from the chip.
    • These tabs lock the chip in place and releasing them will cause the chip to "pop" up.
    • After the RAM chip has popped up, pull it straight out of its socket.
    • Repeat this process if a second RAM chip is installed.
  28. Mac mini Mid 2011 Logic Board Replacement: passo 28, imagem 1 %32
    • Remove the single 5 mm T6 Torx standoff from the heat sink near the edge of the logic board.
  29. Mac mini Mid 2011 Logic Board Replacement: passo 29, imagem 1 %32
    • Remove the following screws securing the heat sink to the logic board:
    • Four 8.6 mm T8 Torx screws
    • One 2.6 mm T6 Torx screw
    • Keep track of the springs held beneath each of the T8 heat sink screws.
  30. Mac mini Mid 2011 Logic Board Replacement: passo 30, imagem 1 %32
    • Remove the heat sink from the logic board, minding any cables that may get caught.
    • If the heat sink appears to be stuck to the logic board after removing all screws, it may be helpful to use a spudger to separate the two components.
    • If you need to mount the heat sink back onto the logic board, we have a thermal paste guide that makes replacing the thermal compound easy.
    • Logic board remains.
Conclusão
25 outras pessoas executaram este guia.
7Comentários do guia
Can you replace the logic board in this Mac Mini Server, with one from the newer faster one, such as the 2012 2.6GHZ i7 server?
jim - Responder
You absolutely can. My mid 2011 Mini logic board died, and I just had a 2012 board put in, which not only upgrades the USB ports to USB3, it also increases bus speed, although the slower RAM 1333 vs 1600 will still work fine.
birdsquared - Responder
I’m wanting to replace my 2011 Mac mini logic board with a 2012. I have a couple questions.
do you need to upgrade your power supply as well?
would the hard drive get formatted(meaning it’ll wipe the hard drive that has important information)?
thank you.
p.s. Dave posted about changing it with a 2014? Not sure if that’s a thing
Daniel W Olson -
Is it worth replacing the motherboard and can you get a replacement with an ungraded graphics chip as the 2011 integrated graphics was not designed for 2k or 4k?
It seems to be the only problem with my logic board and it already been burned torched once.
JB Brighton - Responder
I realize this is an old post. But, I have a Mac Mini 2011 model that works fine, but can no longer update the IOS due to age. I was wondering if I am able to put something like a 2014 logic board in it?
Dave - Responder
Comentar
Visualizações:
Últimas 24 horas: 1
Últimos 7 dias: 12
Últimos 30 dias: 81
Ao todo: 42,268
